Stripping titanium nitride PVD coatings
I'm looking to remove PVD coating from my stainless steel watch.
I tried calling lots of watchmakers but no solution :-(
I'm ready to pay your fees.
Ajay
Ajay verma
Student - Vancouver British Columbia
November 23, 2021
Q. Seeking a source of a stripper for PVD coating (titanium nitride). A variety of substrates is involved. Thanks
Ken Lemke
Ken Lemke
Burlington, Ontario, Canada
A. Concentrated acids, especially hydrofluoric, will dissolve PVD TiN. It is even more difficult remove CVD TiN due to the more conformal surface. Unless your substrate is glass or ceramic, there is a strong likelihood the substrate will be significantly damaged removing the nitride with this method. Sorry, that is one of the advantages TiN surfaces--the fact that they are so hard to remove!
Dale Woika
Bellafonte, Pennsylvania
A. A combination of alkali and hydrogen peroxide are useful for removing titanium nitride from stainless steel (I would recommend a 5% (w/v) of KOH to which is gradually added approx. 30% hydrogen peroxide solution (no more than 20 L to a 100 L KOH solution). The H2O2 is added slowly so as to control the temperature of the etch solution. If the temperature of the solution exceeds 30 deg C oxygen is evolved rapidly and the solution will foam up uncontrollably. ammonia this on eBay or Amazon [affil links] solution can be substituted for alkali (KOH/NaOH) for etching titanium nitride from aluminium.
Brendan Timmins
- Limerick, Ireland
Q. Also seeking a solution for removing PVD TiN. Without damage to the underlying ceramic (AlN) substrate.
Jason
- Daytona Beach, Florida, USA
A. I run a PVD job shop in India.
Most common method for stripping Titanium Nitride is to use 30% or 50% hydrogen peroxide (H2O2) - this works with stainless steel and HSS substrates. But this is slow; will take up to 8 hours. Use a container big enough to allow for foaming and also keep it ventilated; keeping it in sunlight speeds it up.
Catalysts such as NaOH and EDTA speed up the process, but needs more control.
For stainless steel 304 grade, nitric acid + HF works well - over in minutes - but you have to be careful with concentrations (we use 3:1 ratio) to avoid etching of substrate; with 410 grade; we tried, there was heavy etching. Right now we are staying with H2O2
Caution: do not use with tungsten carbide.
Kuppu Swamy
- Chennai, India
How to strip titanium nitride/or titanium aluminum nitride from carbide
Q. This is a problem confusing me for a long time. About a month ago we coated TiAlN on carbide by PVD sputtering method, unfortunately there is a metal layer inside the coating because of the nitrogen pause during the coating. Now I could not decorate the TiAlN without etching carbide, which is very sensitive to acid or alkali. Anybody could help me?
Jolin [surname deleted for privacy by Editor]
titanium coating technology - New York, New York, USA
A. Try heating the parts - the difference in the rate and amount of expansion may crack the coating. It has been years since we have done this but I am guessing it was about 1500 °F or so. Most of the coating flaked off nicely. The remaining residue was easily removed with sandblasting.
Thomas J. Walz
- Tacoma, Washington
Stripping/Removing TiAlN PVD Coatings
Q. I have a problem for removing TiAlN coatings by PVD.
Please inform about the right way for stripping TiAlN.
Thank you very much.
Jiang Zhizhong
PVD company - Zhongshan, Guangdong Province, PRC
? What substrate?
Ken Vlach [deceased]
- Goleta, California
Q. I am looking at stripping a PVD Titanium Nitride coating from a carbide substrate without of course damaging the carbide and would like all the assistance I can get. At this point stripping from stainless steel is no problem at all.
Chris Flattery
PVD coatings - Washington Twp., Michigan
Is there any method to strip a Titanium Nitride coating from a WC-Cobalt substrate after CVD which do not attack the substrate. The solution with H2O2 is not appropriate, I have problem with the cobalt. If you have any suggestion, please give me a comment.
Thank you very much for your help.
Stéphane Junod
University of Applied Sciences - Fribourg, FR, Switzerland
Contact a Swiss company named Balzers. They might help, though maybe not for free.
Guillermo Marrufo
Monterrey, NL, Mexico
If you're lucky, a fluorine-containing plasma will etch TiN and stop at Cobalt, because cobalt fluorides are non-volatile. SF6/H2, CF4/O2 and NF3 are the likely fluorine source-gases. Not sure the S in SF6 is OK if you're re-coating later.
James Swenson
- Los Angeles, California, USA
Q. I work for a PVD company that deposits hard coatings such as TiN or TiAlN on steel substrates. We developed a stripping process which is a mixture of NaOH and hydrogen peroxide (H2O2).
First, I am trying to figure out what is the waste produce by the stripping reaction? Second, when I transferred the process to production I have had some difficulty in controlling the reaction. In our lab, even at high temperature (~70 °C), the foaming doesn't get out of control but in production we have had a few overflows due to excessive foaming. One difference that was identified is the use of a steel tank in production as opposed to glass beakers in the lab. Any thoughts?
Steve Guetre
engineer - Montreal, Canada
September 11, 2008
A. I am a bit surprised that you did not have any problem in the lab at 70 °C.
The breakdown from heat of H2O2 appears to be logarithmic. It becomes self destructing extremely rapidly at some temperature. I have seen it become nearly explosive. I bear the burn scars from it.
In production you may have more material to strip per unit of solution . Heat is a product of the breakdown.
If units are comparable, then I will guess that in production you are generating more heat than the tank can get rid of whereas in the lab the heat transferred to the atmosphere faster for some reason.
Possible solutions would be to strip less material at one time paying close attention to the initial temperature, or adding a cooling coil that would kick in at a given temp to control the temp rise.
Stripping method for titanium carbon nitride?
Q. We do titanium carbonitride through PVD process for watch components made of brass - Nickel and flash palladium plated. Stripping of defective components becomes difficult due to etching of HF and HNO3/HCl mixture. Another another solvent or method is there to strip titanium carbonitride?
Ramasubramanian Sankaran
plating shop employee - Bangalore
January 20, 2009
Q. Dear sir,
we are doing CVD TiN coating with (aluminium alloy as base metal) in our industry and I wish to know how can I remove this coating in any case without affecting the base metal.
Nitin
Nitin Sardana
Patiala, India
November 19, 2010
A. Hi, Nitin.
We appended your inquiry to a thread which hopefully answers it. Please see the response from Brendan Timmins above.
Another good thread about stripping titanium nitride is letter 11499. Good luck.
November 19, 2010
Q. Two questions:
1 - looking for solution on stripping TiN from Titanium substrate
2 - looking for solution on stripping AlCrN from Carbide substrate where the main problem is Cobalt leaching
Ilcho Aksovski
- Clinton, Michigan, USA
October 1, 2012
Ed. note: These threads about stripping TiN are already long and a bit meandering, so please see letter 53089 for your second question. Thanks.
