How to reduce brittleness in Nickel Plating
"Nickel Plating Handbook 2023"
by The Nickel Institute
nickel_institute_handbook
View On-line for Free
I am from Brazil and here electroforms are not used. I have a bath of nickel sulfamate and I am having problems. The deposited nickel is brittle. Can anybody help me? Excuse me my English it is bad.
ALVARO PINHEIRO
electronics - SÃO PAULO, BRAZIL
A. Without knowing what you are doing, your problem cannot be solved. Brittleness in an electroform can be due to almost anything, ranging from bath contamination through to the wrong (or out of specification) solution, wrong current density, wrong pH, wrong anodes and wrong temperature. You must provide details of what you are doing before anyone can help you.
nickel book
The Sulfamate Nickel How-To Guide
by David Crotty, PhD & Robert Probert
Q. I am forming cavities of mold thermoplastic -temp. 50 °C -pH 4,0 -current 6amp/dm2 the deposition is on top of silver ink.
ALVARO PINHEIRO [returning]
altera - Brazil
? Bath composition?
Q. My bath has 500g/l of nickel, 35 g/l boric acid, 2 ml/l of mechanical washer, 1 ml/l of leveling
altera - Brazil
A. Hi ALVARO. Surely there's a typo there with regard to nickel concentration, which is 5 to 7X what it should be.
"Mechanical washer" is obviously a mistranslation, maybe you mean "hardener solution"? ... maybe you should have none. I would suggest that you plate a Hull Cell panel and tell us what you learn from it. Luck & Regards,
"INCO Guide to Nickel Plating"
by International Nickel Ltd.
Q. Dear sir
We are getting Nickel Electroplating over Copper on mounting brackets of Switches made out of Mild Steel. But we find that the plating is peeling when we are folding the legs of the brackets during assembly. Could you guide as to how to reduce the brittleness to prevent the peeling.
V.Venkappa
Manufacturer of Professional Grade Switches and Analytical Instruments - Hyderabad, Andhra Pradesh, India
A. Are you doing the plating in house or outsourcing it, V.?
Try to determine where the separation is taking place. If between the substrate and the copper, it is probably a pretreatment issue. If there are multiple layers of nickel blisters, that may be laminar plating from reprocessing of rejects or interrupted nickel plating. If the nickel plating itself is actually cracking it is indeed too brittle. Bright nickel often is, and you may need to go to a sulfamate nickel coating.
A. If you have checked that the pretreatment is OK then you need to look at low leveling nickel brighteners and also get is a stress sequestrant that will nullify any compressive or tensile stresses in your deposit; after getting this into your nickel bath, ensure plating thickness within 5 microns.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
See also:
Topic 1269 "Need Ductility in Nickel Electroplate"
Topic 4503 "How to reduce brittleness in Nickel Plating"
