Rusting Nails student experiment & research (cont'd)
< Prev. page          (You're on the last page of the thread)
Q. Hi, It's me...again...I have reviewed my results and so far:
the nail in salt water rusted the fastest,
the nail in the vinegar ⇦ in bulk on eBay or Amazon [affil link] turned black, and
the nail in the orange juice turned black as well.
I was wondering why? why did the one in saltwater rust the fastest, the vinegar and the orange juice turned black? And I was wondering how to graph the results...do I weigh them again...or do I just measure the height of the rust in the nail? which is more accurate?
Please I really need your help. And thank you very very much for all the help you have done in my project. I will surely put you on my acknowledgment. Thanks again..God bless!
Chelsea C [surname deleted for privacy by Editor]
- Laguna, Philippines
July 7, 2010
A. Hi, Chelsea. Although this has been explained a dozen times on other threads on this site, it is probably hard to find, so I'll bore some readers by repeating the explanation here :-)
Students (and some teachers) assume that rust is the best indication that corrosion is occurring, but it isn't! In fact, in industry, acids are used not to create rust but to remove it. Although acids can dissolve metal, they will dissolve rust faster, leaving the surface rust-free.
So what has happened is --
With your vinegar and orange juice, any rust has been dissolved into the acid. In addition, a very small amount of iron has probably also been dissolved. Steel nails are made of iron plus a small amount of carbon. As the iron dissolved, it left behind the very tiny specs of carbon because carbon is not soluble in mild acids. You will probably find out that this black "smut" can be wiped off with a tissue or paper towel. But I'd suggest wiping it off onto a coffee filter instead, so all of your corrosion products are "mounted" on coffee filters.
In the salt water, the iron from the nails combined with oxygen dissolved in the water to form iron oxide (rust). I'd suggest rubbing any rust off onto a coffee filter and pouring the liquid through the coffee filter.
The amount of rust and smut on the coffee filters should be a good measure of what happened. The ideal way to measure corrosion is by the reduction of weight of the nail between start and finish, but I doubt that you have scales of sufficient accuracy, so you may have to exhibit your coffee filters as your measurements. You can do a rough graph of how much smut and rust you see on each coffee filter. Good luck.
July 7, 2010
Q. Hi, it's me again. I am almost finished with my written report but I still don't have a hypothesis...I'm sure you're not allowed to give a hypothesis to me, but I was wondering if the hypotheses I chose is correct. My hypothesis is that the nail in the salt water will rust the fastest. I'm a little bit confused. My topic is the effects of different contaminants on the rate of rusting. So I don't think my hypotheses is right for my chosen topic. What do you think?
Please help me...I really really need your help...
Thank very much....
Chelsea C. [surname deleted for privacy by Editor]
July 8, 2010
A. I can't be anybody's tutor or personal advisor, Chelsea, and this is my 4th response to you -- but hopefully this dialog will be helpful to other students.
Let's take it from the top --
You don't just start an experiment with no purpose. As I noted in my response to Zoe in about the middle of this thread, Darwin himself said that this would be like going into a gravel pit every day and pointlessly writing down the size and color of each piece of gravel. There needs to be a point to your experiment, something that you are trying to prove or disprove. That "something" is your hypothesis.
The "hypothesis" that you now suggest might have been okay, but you were supposed to form your hypothesis before you began your experiment, and the purpose of the experiment was to see whether the evidence supported or tended to refute your hypothesis. The position you are in now is that you want to use your "conclusion" that salt water rusts things fastest as your hypothesis. See the problem, and why that's no good?
So let's look at it this way: when you began your experiment, you suspected that different contaminants would affect the rusting rate. You didn't know it to be a fact, you just suspected it based on intuition, previous experience, or rumors you heard, etc., right? What you wanted to do was to conduct an experiment to support or refute that suspicion. So, how about this as your hypothesis: "When nails are immersed in water-based liquids, the amount of rust that is formed will vary depending upon what contaminants are in the water they are immersed in."
So you picked a good variety of liquids (salt water, sugar water, vinegar, orange juice, and Dr. Pepper) and ran an experiment to prove this hypothesis -- and the conclusion was pretty clear: the amount of visible rust on the nails in salt water was the greatest. You also discovered that immersion in vinegar or orange juice produced a black smut on the nails. You believe that this black smut is carbon that did not dissolve in these mild acids, but you do not know that for a fact, so you suggest a good hypothesis for next year's science experiment might be: "Immersing nails in vinegar or orange juice dissolves some iron from their surface, leaving behind a carbon smut".
July 8, 2010
Q. Good day, My name is Naomi and I was assigned a rusting rate project. We also had to write a written report but I don't have a problems or specific questions to answer in my project. So far, my problems are: Which of the contaminants have the most significant effect on the rate of rusting iron nails?
Which nail rusts the fastest?
What properties are present in the contaminants that may have an effect on the nails?
Are those related or acceptable in my topic? My topic is the effects of salt and other contaminants on rate rusting?
Please I really need your help.... Thank you!
Naomi F [surname deleted for privacy by Editor]
- Los Angeles, California
July 12, 2010
A. Hi, Naomi. Are you in 2nd grade and this is your first-ever science project, or are you a senior in high school, with a wealth of such projects behind you, and ready to start your career or head off to a university?
I'm not trying to give you a hard time, but please understand that students are expected to learn an awful lot in those nine or ten intervening years, so a senior project bears no resemblance to a 2nd or 3rd grade project and nobody can help you plan a project until they have some sense of how deep your knowledge of chemistry is supposed to be at this point.
Step 1: tell us what grade you're in :-)
July 12, 2010
Q. Hello....
I'm in the 9th grade and I have a question about my project which is the effects of different contaminants on the rate of rusting. On the previous answers you have given, you said that you can measure the rust by rubbing the rust off the nail. How do you measure the rust that was rubbed? And as you answered in Chelsea's question, you stated that the black smut that was found in the nail in the vinegar are carbon specs left behind. I wanted to ask if it was still considered as rust?. Because that also happened in my project.
PLEASE PLEASE HELP ME! I DESPERATELY NEED YOUR HELP...THANKS!
Ella C [surname deleted for privacy by Editor]
- Makati, Philippines
July 19, 2010
A. Hi, Ella. If you desperately need help, I feel you are probably not properly interfacing with your teacher because it was most certainly not your teacher's intent to force you to contact strangers on the internet to help you :-)
The ideal way to measure rust is to weigh the nail before you start the experiment, let it rust in the solution for your experiment, then use special chemicals to dissolve away the rust, and then weigh the nail again -- determining the amount of corrosion by how much weight of metal the nail has lost.
But depending on what grade you are in, what chemicals the school lets you use, and what equipment your school has, you probably have to compromise rather than doing it the ideal way. A compromise which is probably suitable for younger grades is to rub off any rust you can onto a coffee filter, and pour the rusty water through the same filter.  You can't actually "measure" rust this way, but I think you can "judge" the relative amount of rusting by looking at how much rust is on the filter.
I am only guessing that the black smut is carbon specs; neither of us has done an experiment that proves it. But, no, carbon is not rust. "Rust" is iron oxide, the chemical combination of iron from the nail with oxygen from the air or dissolved in the liquid.
I believe the right approach to your report is to understand the principles that we've talked about here, and describe what you've found and the limitations on what you've been able to do based on a student's limited access to chemicals and exotic testing equipment. Good luck!
July 19, 2010
Q. HELP! Based on other studies in this site, the nail that was immersed in vinegar turned black...mine didn't! It was black for the tenth day but since my experiment was for 14 days I didn't take a picture of it ... When the fourteenth day arrived the said nail was black and the one in the salt water had less rust ... what happened to my project? By the way I'm an eleventh grader and my project is the effects of different contaminants on the rusting rate on nails..
Please Help me ... I desperately need it!
Thank you!
Casey R [surname deleted for privacy by Editor]
- Lockport, Illinois
July 21, 2010
A. Hi, Casey. Sorry but I can't even understand what you are trying to relate -- you have said you expected it to be black and it was, both on the 10th day and the 14th, but it seems that what you said isn't what you mean. So I think the most important thing you need to do is work on a careful description of exactly what you did and exactly what you saw. The methodology of your project and report is far more important than getting the "right" answer. Explain what happened very carefully, then advance a theory that might explain it, and research whether the theory makes sense. Good luck.
July 28, 2010
Q. Hello, What I meant with the question was that in my experiment, the nail that was in the vinegar rusted the most, while in most of the research that I saw salt was supposed to rust more. I followed the procedure that was to weigh the nails before and after the experiment. But before I weighed the nails after the experiment, I cleaned the rust off to see how much weight is lost. In my project, It showed that vinegar had the most weight loss, while salt had the least weight loss. I just wanted to ask why it happened? Why was vinegar the nail that had the most rust?
I really really really need your help. This project is due next week and I still don't know why the results happened. Please Please help me.....Thanks....
Casey R [returning]
July 29, 2010
A. Hi, Casey. I know you don't quite believe me, but you continue to not carefully define for yourself what the words you are using mean. I can see you tossing the word "rust" around in an inconsistent fashion, where you mean visible rust one moment, total dissolved iron the next time, amount of weight loss the third time, and back and forth. Until the words you use have a fixed & stable meaning to you, you will continue to flail around in circles of confusion. Look up the definition or decide for yourself exactly what that word 'rust' means to you, and never use it in a different way.
Of the solutions that you are using, vinegar is the most corrosive. That is because it is an acid, and acids directly dissolve iron into solution. But as mentioned several times on this thread already, acids are more commonly used to dissolve rust than to create rust; that is because they will dissolve rust faster than they will dissolve metal, leaving a rust-free surface.
Here is what may be happening. The vinegar initially dissolved any small amount of rust that was on the nail, then it began to slowly dissolve the iron itself (as proven by your weight loss measurement). So now the vinegar/water solution has iron dissolved into it. The acetic acid of the vinegar, over time, leaves the solution as a fume or vapor (that's why you smell it). At the same time, the water is also evaporating. At some point, as the acid and water go missing, and the iron that was dissolved remains behind, it can't stay in solution because it's too concentrated for the remaining acid and water to keep it dissolved. This should not be a surprise, sweat is salt water and it leaves salt stains behind as it evaporates too. The dissolved iron reacts with the air and water and forms rust. Since vinegar dissolves the most metal (iron), the residue will have the most iron, and when that residue eventually dries and converts to rust, there will be more of it.
Again, sticking with consistent meanings for words: nobody said salt water is more corrosive than vinegar; it isn't! What they said was salt water will produce visible rust whereas vinegar, at least initially, does not create rust but dissolves it instead; but when it's capacity for holding the metal in solution dissipates, the metal is left behind as rust, and because it dissolves more iron than water does, you'll see more when everything is dried up.
July 29, 2010
Q. Please help me.... I'm a ninth grader and I did a rusting project. The effects of different contaminants on the rate of rusting. The contaminants that I chose were OJ, vinegar, and salt water. The nail in the vinegar rusted the most followed by orange juice, and then salt water. I know that the vinegar is acetic acid and dissolves metal and corrodes only when it is evaporated. But I wanted to ask about salt water. why did it rusted the least? Is it bec. it has a higher pH level? Or does it have something to do with electrochem?
Please help me...need a response by hpoefully tom....thank you so much....
Erika R. [surname deleted for privacy by Editor]
August 5, 2010
Q. Hey ted I'm kim and µm I'm doing a science project on the effects of soda on nails and I'm using dr. pepper, coke, vanilla coke, cherry coke, water, pepsi, and sprite now I've been told that nothing will dissolve keratin nor steel nails but what are your thoughts? and also I have to do note cards with this experiment how would I get A LOT of info that can fill 50 note cards? sincerely,
Kimberly Grace
Kimberly Grace E [surname deleted for privacy by Editor]
science I guess - Florida, U.S.
October 5, 2010
A. Hi, Kim.
50 note cards?! Does your teacher prefer Edward Everett's style to Abe Lincoln's? :-)
If I had my choice I would not use 6 different brands of soda, all of which probably rust stuff rather similarly (because they have the same basic ingredients of water, sugar, and phosphoric acid). The actual ingredient lists are secret, so if do find any difference in corrosiveness you'll never know why.
There would be little of extensible value that you can learn from such an experiment. So what is "extensible value"? Can you add 201 plus 103 right in your head right on the spot? Sure you can. Even though your teacher never taught you to add those two specific numbers together, you can add them because your teacher did show you the "extensible" method of adding the units column, then the tens column, then the hundreds column. But if you find that soda A is more corrosive than soda B, so what -- what else does it tell you or teach you? Nothing at all, and they could change the formula tomorrow anyway :- (
So please try to redesign your experiment with questions like: does the temperature matter, does more sugar increase the rusting or slow it down or have no effect, does the concentration of salt matter, does the concentration of acid matter (for example, straight vinegar vs. 50:50 vinegar to water). Try to find some property or aspect of your test solution that is measurable in some way, and see whether varying that property or aspect affects the rusting. Good luck.
October 5, 2010
Q. Hello I am in 6th grade and I am doing a science fair project on "science What liquid will make a nail rust the fastest?" my materials are: vinegar, tap water, sprite. But I need an idea for the Procedure....
Write me back as soon as you can thanks!
Marie p [surname deleted for privacy by Editor]
science fair - New york
October 19, 2010
A. Hi, Marie.The answers are already on this thread repeatedly. Please ask your parents to review your understanding the word "procedure" and help you find the procedures that are described on this page. Good luck.
October 21, 2010
Q. I am a 7th grader and I need to know what the chemical reaction would be when vinegar rusts a nail. I saw the black stuff on it and want to know what it is.
Alisha V [surname deleted for privacy by Editor]
- Plano.Texas
December 10, 2010
A. Hi, Alisha. This is pretty advanced for a 7th-grader, but the chemical formula for vinegar (acetic acid) is vinegar is HC2H3O2, and it will ionize to H+ + C2H3O2-. The chemical formula for an iron or steel nail is basically Fe.
The reaction is approximately Fe0 + 2H+C2H3O2- ==> Fe++(C2H3O2-)2 + H2^.
The iron goes into solution as ferrous acetate, and bubbles of hydrogen gas are released to the atmosphere.
December 12, 2010
Q. I have a 10 year old 4th grader that is doing a science fair project and I was never good at science and do not have all the answers to help him. I have read some of the threads and it helped me understand some to help my son understand his project, but I am left with other questions. He is doing a project on which of bleach, tap water (we have well water), or salt water would rust an uncoated framing nail the fastest. He has done the experiment twice now and has had very similar results. We found that the bleach rusted the most and quickest and I think I have gathered from some of the other threads on why as it basically has more oxygen released to cause the iron to oxidize more and quicker. I think I stated that correctly. Anyway, the tap water seemed to rust a bit more than the salt water in both of the experiments. I saw that you have done this experiment yourself and came to the conclusion that they rust about the same. My question would be why would in my sons experiments the tap water rust more than the salt water both times. He needs a reason to place with his graph he places on his poster board for the project and I have no idea on where to begin to look for an answer. My son is a straight A student which he gets from his father. lol He wants to excel and I am trying to help and I feel like someone is speaking a foreign language to me when it comes to science. My son suggested that the salt in the jar that the nail was half submerged in was preventing oxygen to be released and in turn caused less rust. I don't know if this is correct or not and don't want him looking silly with this conclusion if it's wrong. I just don't see what can be gained from this project besides him learning how to do one. He's been doing the journal and understands to get accurate results that an experiment must be done a few times to maintain the same results. But why would knowing that bleach rust something more be helpful? It's not like bridge building companies for example would have to worry about bleach getting on their bridge and corroding it.
Jackie Brown
- Boggstown, Indiana, USA
February 10, 2011
A. Hi, Jackie.
In the long term, in the real world, we know for certain that salt water is more corrosive than fresh water. This is known by every sailor, every engineer, and every homeowner with a beach house; and it can be easily proven by well controlled accelerated corrosion tests. There are at least two reasons: first, chloride ions, as in sodium chloride salt, chemically attack metal and are corrosive to it; secondly, the dissolved salt increases the conductivity of the water, allowing galvanic corrosion currents to flow easily.
But what can we say of short term tests by students? After dealing with reports of hundreds of tests here for many years, many reporting salt water to cause more rust, and many reporting fresh water to cause more rust, I ran the test myself and was unconvinced that there is any significant difference. If we then try to answer the question of WHY one is more corrosive than the other, we are confronted with the problem that the student actually has insufficient evidence to make such a claim in the first place because countless students got the opposite result :-(
One of our readers (Poppy Anne, letter 19024) claimed that the reason that fresh water is reported as more corrosive is that in the short term it is, but it builds a film of corrosion products on the nail that tend to slow further corrosion, whereas salt water penetrates this film and continues to corrode. I don't fully believe this, but it is one possible explanation. Perhaps another explanation is that as iron dissolves into these smallish dishes we quickly approach an equilibrium condition where the dissolved iron slows further dissolution, and the results would be entirely different in flowing water.
In short, I think your son should do the experiment as conclusively as he can, then try to advance an explanation, but introduce this information about the uncertainty of the results, because there are simply too many contrary results to dismiss them all based on testing two or three nails :-)
Your question about the significance of learning that bleach causes a lot of rust is a good one. But the internet is a giant one-room schoolhouse and while 4th graders don't know enough chemistry to learn an extensible lesson from this, high schoolers should. Another issue is that 4th graders can't use "real" chemicals for safety reasons (even high schoolers sometimes aren't allowed to these days, although for that age group I think it is shameful paranoia rather than a legitimate safety concern); this limits the cause-and-effect lessons they can learn. Your son is doing a good experiment for a 4th grader though.
February 11, 2011
Q. Hey guys, I'm a grade ten student studying different pH's effects on nail corrosion.
We used HCl (aq) with a pH of 1.6, a mixture from our teacher of HCl (aq) and water with a pH of 4.3, and tap water with a pH of 6.
What we found was that the higher pHs produced what appeared more corrosion, but when we extracted them from the test tubes and removed their rust, the nail stayed the same weight! The lowest pH did however weigh the least, but there was very little rusting. I assume the acidic part of the HCl removed the rust, and I understand that, but I don't understand how the very "rusty" nails didn't change in weight!
Savannah K [surname deleted for privacy by Editor]
Student - Burlington Ontario Canada
March 27, 2011
A. Hi, Savannah. Rust can be very fluffy stuff like cotton candy, occupying a lot of volume and calling attention to itself when there isn't much substance. Although the rust weighed something, it was probably little enough that it was beyond the resolution of your scales. You did good.
March 2011
Q. I have an experiment project in school ... but I always forget to do it ... but I just wanna ask what happens to a nail placed in a glass jar without water and uncovered?
And what happens to to a nail placed in a glass jar with water and is covered? does the nail in the water or or the other forms rust on it's surface? please answer .. :)
cristea s [surname deleted for privacy by Editor]
student - philippines
June 21, 2011
Hi, Cristea. Sorry, but faking a project is not something I want to help you with :-)
Q. Hi, my name is genesis and I'm in the 9th grade. I'm doing a project based on rusting. I did my experiment and found that after a day of being in salt water and distilled water, nails rust faster in distilled water. Can you please explain why this happened?
Genesis P [surname deleted for privacy by Editor]
- Boston, Massachusetts
December 20, 2011
A. Hi, Genesis. We appended your question to a thread that answers it. Please see my response of Feb. 11, 2011, wherein I say that an experiment with a couple of nails under somewhat uncontrolled conditions may not render a conclusive result. But stuff can only dissolve to an equilibrium point, and I suppose it is vaguely possible that something similar to the "common-ion effect" could mean that the sodium and chloride ions in the saltwater could slightly slow down the dissolution of the iron compared to purer distilled water which has nothing dissolved in it yet. Distilled water can be "hungry" to dissolve stuff. Please patiently google "hungry water" to learn more. Good luck!
December 21, 2011
Q. I helped my daughter post the following observation/request in a different post, but I am doing so here again because the topic here seems closer to her project and questions. My daughter and I will appreciate all explanations from the chemical professionals.
My 11 year-old 5th grader is doing a project on which 'environment' will cause rust to form fastest. She has used 6 non-galvanized nails cleaned with rubbing alcohol and placed in 6 test tubes filled with NOTHING, RICE, TAP WATER, OIL, vinegar, and BLEACH, respectively.
After nearly 7 days of observations and data recording, we have seen some expected results and some puzzling occurrences. All tubes were left at avg room temp of 70 °F and avg humidity of 40%. The tube with NOTHING had no rust to show - as expected because it would take a long time to form. The tube with RICE also showed no rust - presumably because of the hygroscopic property of rice. The tube with regular TAP WATER did show rust on the nail and lots of rust particles settled to bottom. The nail in OIL showed no rust - presumably due to the oil creating a coating around it and preventing oxygen and moisture from contacting the nail's surface. The nail in vinegar gave us a puzzle: there was no rust on the nail which was submerged in vinegar, but the surface outside of it was covered with an extremely crusty, dark reddish-brown and black substance (i presume it is rust, but it didn't look like what we saw in tap water.) The nail in BLEACH caused amazing rust-like clumps to form within a few days.
We expected the rust in water, but the results in vinegar and bleach has me stumped. I don't have an explanation for my daughter as to why the submerged half of nail in vinegar is free of rust but the surface untouched by the acidic liquid is covered profusely with dark rust-like material. Nor do I know what to say about the profuse clumps of light brown rust in the tube with nail and bleach.
I have read other posts having similar results, but I am not clear as to the WHY of the results. PLEASE HELP ME UNDERSTAND.
Roshni PARKER
- Houston, Texas, USA
January 2, 2012
January 2, 2012
Hi, Roshni.
Okay, you understood the first 4 results but not the vinegar result or bleach result. You also seem to understand that rust is an iron oxide, which is the reaction product of iron plus oxygen.
Vinegar is dilute acetic acid. Acids, as you may have seen in Hollywood movies, dissolve metal. Acids also dissolve rust. So, as long as you have vinegar left in the solution, and it's not exhausted (i.e., the acid hasn't evaporated away, nor become fully saturated with dissolved metal), there will be no rust on the nail because the vinegar has dissolved it and is continuing to dissolve it. Were the vinegar to dry up, the dissolved iron would no longer be dissolved and would quickly react with oxygen from the air to form rust. That is basically what is happening to the part of the nail that is not in solution. The acid vapors dissolved some of the metal, but since that half of the nail isn't wet, the iron can't stay dissolved, but reacts with the oxygen in the air to form rust. At the end of the experiment, you may want to pour the contents onto a paper towel and let it dry to see how rusty the paper becomes.
The bleach situation is a little different. Bleach is sodium hypochlorite, NaOCl. Chemical reactions can be complex, and viewed from different perspectives, but one way to look at it is that there is an awful lot of O in NaOCl that wants to react with iron to form iron oxide (rust). If no iron were present, the decomposition from NaOCl to NaCl + O would proceed quite slowly, but if there is iron available, the decomposition proceeds very quickly with the available iron locking up the O as iron oxide,
NaOCl (bleach) + Fe (nail) => NaCl (salt water) + FeO (rust)
Typical red rust is actually Fe2O3, rather than FeO, and the rusts you form under water may be iron hydroxides rather than iron oxides, so the formula I gave you is somewhat simplified; but it should convey the idea in more than sufficient depth for 5th grade. Good luck.
Q. I am doing an experiment on how easily galvanised iron nails go rusty compared to ordinary iron nails?
Priya R. [surname deleted for privacy by Editor]
- Guyana
January 17, 2012
February 15, 2012
thumbs up signTo Mr Ted Mooney and everyone else who helped us get explanations related to my daughter's 5th grade science project on rust... THANK YOU FOR ALL YOUR HELP!
My daughter's work earned her a TOP 5 in her school's 5th grade classes.
Besides the gratification of earning such recognition, my daughter has also learned some things that I could never have explained to her if it were not for the generosity of the experts moderating this forum.
KEEP UP THE GREAT WORK!
Roshni PARKER [returning]
We appreciate the compliment, Roshni, and thank you for taking the time. But as I'm sure you know, your daughter earned a Top 5 because she put in the effort. Thanks again.
February 16, 2012
Q. hey yall listen I need help so go down
keep goin
can yall help me. I need facts on corrosion of a nail in Coke, Sprite and Sunkist. I am using a steel nail.
keep goin
you have reached the end bye-bye' y'all want a cookie? ps. I'm in the 5th grade
Mary Z [surname deleted for privacy by Editor]
- Upper Marlboro, Maryland
February 20, 2012
Q. I am doing a science project on how does the acidity of a solution affects the rate of oxidation of an iron nail. I really need help on my procedures.
Sahra [surname deleted for privacy by Editor]
- United State of America
May 14, 2013
A. Hi Sahra. Since you want to know the effect of acidity of the solution, you need to know the acidity of the solution. Your teacher will either give you pH paper (litmus paper) to test the acidity, or will tell you the pH of various solutions, or will ask you to research it. That's step 1 in your procedure then: figuring out how you are going to know the acidity of the solutions.
May 14, 2013
Q. I am a 7th grader doing a project on rusting nails. I need to know what the variables are for rusting nails. If you find anything please let me know. Thanks.
Adrianna S [surname deleted for privacy by Editor]
- Raeford, North Carolina
October 29, 2014
A. Hi Adrianna. If you look at Angela B's letter above, she describes the independent variable, the constants, and the dependent variable.
Our FAQ "What juice or liquid cleans pennies best?" explains those terms, and all the terms used in your project. Good luck.
November 2014
Dependent vs. independent variables
February 10, 2015
I am a parent helping a 4th grade student with the rusting nails science fair project.
We need to list independent and dependent variables. I am just at my wit's end trying to understand the difference.
HELP!! And, how can I know the difference between the two? Can you share a possible resource to help me with this confusion?
Angela Jefferson
- Laurel, Maryland
A. Hi Angela. If you go nice & slow and don't panic, it's actually very easy :-)
A variable is anything that is changing/changeable as opposed to being constant/fixed. And you already know what independent means and dependent means.
If you put the words together, an independent variable is something we choose to change or vary, and a dependent variable is something that changes as a result of that choice. In everyday life, you can choose how much to eat (independent variable); then how hungry you still are when you get up from the table is a dependent variable, and how much weight you gain or lose is another dependent variable, and how much the dinner cost might be another dependent variable. You can choose to buy a Prius or a Humvee or a Ferrari (independent variable); then the average gas mileage you get is a dependent variable, and how much the car payments will set you back is another dependent variable, and how likely you are to survive a 40-mph crash could be yet another dependent variable.
There might be a thousand dependent variables in theory, but you don't necessarily have to be interested in all of them. For example, in choosing a car, if safety & survivability is extremely important to you, you might not care about gas mileage or cost (or leg room or top speed or trunk capacity or other facts & figures).
When it comes to an experiment about rusting nails, independent variables you might choose include what the nail is made out of, or what coatings you put on the nails, or what solutions you expose the nails to, or what temperature the solutions are, or how long you leave the nails in the solutions. A 4th-grade student will probably only vary one thing, for example what juices to use as their solutions. Generally, the dependent variable that you will be interested in is how much rust you get.
There might be other dependent variables in theory but you might not care about them. For example, if you chose to use vinegar in one of the experiments, you'd have less vinegar left in the bottle (dependent variable) but it's probably not a variable that you care about, and doesn't impact the experiment your child wants to do. So THE dependent variable for your child is the amount of rust. Good luck.
February 2015
thumbs up signTHANK YOU, so very much!!! The way you explained it, makes perfectly good sense.
This website rocks!!!!!!!
Angela Jefferson
- Laurel, Maryland
February 13, 2015
Does temperature affect the time it takes for iron to rust?
Q. Alright so I need to do a science project and I chose this. I will be using the following: 4 of the same type of metal (Iron), same container (size wise and brand), and finally same type of water(Tap Water). The first container will be filled with water to about 1 1/2 inches with the piece of iron centered. The same will be for the rest.
The locations for each container will be the following: First One: Sun Light, Second One: Outdoor Shade, Third One: Indoors on a table/counter top, Last One: Inside a refrigerator. I will be constantly measuring the temperature on a graph for about 3 - 4 weeks. I would like to know if this is an efficient way to do my project? If not how else could I do it?
Giancarlo F
Student - 6th Grade - Miami, Florida, United States
October 3, 2015
A. Hi Giancarlo. Your experiment sounds fine to me but there are a couple of things to watch for. First, that the solution in one or more containers may evaporate; I think you should have a fill line on the containers and periodically top them up if they get down to the 3/4 mark or so; or even better might be to cover them (maybe your mom has four matching tupperware containers with lids). Second, you might say that you have attempted to limit the effect of sunlight, humidity, and other factors by covering the containers, and are making the as-yet unproven assumption that those factors have not influenced your results. Have fun.
October 2015
December 22, 2015
chemistry pd lab
topic: corrosion race
problem: plan and design an experiment to see which nail would rust faster (ordinary iron nail or galvanised nail).
nikkita wilson
- georgetown, guyana, south america
Hi Nikkita. Yes, that sounds like a good science question/experiment. But so far you have done nothing (that you've shown us) except to post your homework assignment :-)
Please tell us what you have planned, or ask questions about what you see on this page, or something, anything, that we can comment on rather than simply doing your homework for you. Thanks.
December 2015
Q. What happens to an iron nail after three days in sugar water?
Melinda A [surname deleted for privacy by Editor]
February 1, 2016
A. Hi Melinda. Please describe exactly what you see, maybe including pictures if possible, and we will try to explain it.
March 2016
Q. I am doing a grade 8 experiment on rusting nails. I am using water based paint and oil based paint and placing them in test tubes with tap water. I know that the oil based is more effective in stopping corrosion... but why? Why does oil based paint prevent corrosion better than water based paint?
JOE B [surname deleted for privacy by Editor]
- Florida, USA
October 28, 2016
A. Hi Joe. Can you attach photos or your interpretation of the results?
While it is true that some oil-based paints are better at preventing corrosion than some latex water-based paints, I don't think the general hypothesis is necessarily true. Whichever paint is most free of tiny pinholes, thickest, and best adhering is probably most effective. Additionally, some paints are specifically designed to deter rust, and may have rust-preventative chemicals in them, whereas others may be intended primarily to be used on wood and would not include the rust preventative.
I would suggest documenting as carefully as possible any notes on the paint cans that may help explain the differences.
Now if you were comparing water paints that preschool children use in coloring books to oil paints that professional artists use, water paint is designed to immediately wash away with water, so they offer no protection at all from water. Good luck!
October 2016
Q. Hello, I am a tenth grade student in Sydney, Aus and for my current assignment I am required to conduct and analyse a chemical reaction that occurs in a real world situation. I am thinking of doing corrosion or rust however I have a few questions. If I was to do rust (I know it is a form of corrosion) I would use preferably an iron nail in say three or four different liquids, however how would I measure the rust (using qualitative data) effectively? I heard it is quite difficult and its putting me off from doing rust.
If I were to choose corrosion, how would I conduct an experiment? would it be better to do different metals in the same liquid (water probably) or same metals in different liquids? Thank you for your time.
Georgia Xippas
- Sydney, NSW, Australia
February 29, 2020
A. Hi Georgia. In our commercial & proprietary world it can be a bit difficult to determine the exact composition of a metal, so it can be tough to come up with good conclusions from exposing several different metals to the same solution. So I think the idea of exposing identical nails to different solutions is more promising.
I'd suggest laying one nail each in four shallow saucers, and pouring just enough liquid over each to wet the nail, and after 3 or 4 days or as many as you can allow, if the saucers have not dried up, put them in the sun or on a warm radiator until they do. But keep everything identical: the same quantity of liquid poured on each, the same time in the sun or on a radiator, etc.
The dry saucers with the nail in them can be your exhibit. Some will be noticeably more rusty than others. 4 possible liquids are tap water, tap water with a little baking soda, vinegar, bleach. Don't mix any liquids together. Good luck.
February 2020
June 5, 2020
A. Georgia,
Corrosion is a very interesting subject. One experiment you may wish to try is to use some iron (or steel) nails - make sure they are ungalvanized (i.e., not coated in zinc) or coated with anything else, such as paint or lacquer and are not stainless steel. The cheaper the nail, the better!
I suggest you clean them with a good washing up liquid to make sure they are not coated in any grease or oils and then carefully dry and weigh each one with a chemical balance (don't use kitchen scales because these are accurate enough!)
Then put one nail into flasks or bottles containing each of the following liquids: 1) tap water; 2) boiled tap water; 3) Coca Cola/Pepsi Coal (or the Australian equivalent); 4) dilute hydrochloric acid; 5) 5% sodium chloride (salt) in tapwater. You will also need a "control" so put another nail is a flask of boiled tap water and seal it from the air with a layer of candle wax (let a burning candle drip its wax on to the top of the boiled water until it forms a continuous layer about 2-3mm thick). Do not touch your control container until the experiment is over.
I suggest you then put the flasks or bottles in a safe place and give them all, except your "control", a gentle shake for about a minute at least twice a day (say morning and evening). Do this process for as long as you possibly can, but this will depend on how long you can take over your assignment.
At the end of the test period, examine the nails and note what you see. Then take then out of the various liquids and carefully dry them. If any of them have rusted, make sure you also collect the rust, dry it and also weigh it. Add the weight of the rust to the nail it came from. Then compare the weights of the nail(and any rust)at the end of the experiment and compare it with the nail's original weight. Make sure you do not mix the nails up!
Report what you see in regard to the nails and any rust and compare the results for each solution.
As a further clue, the purpose of shaking the containers is to allow air into the solution, whilst the purpose of sealing the "control" in boiled water and under a wax layer is to prevent air getting into the solution.
Have fun!
