Penny Rust: Safe, Smart Corrosion Test Ideas That Work
Summary for penny rust Discussion
Penny rust is the wrong term here, because Ted Mooney explains that pennies do not actually rust: rust is iron oxide, and pennies are copper plated over a zinc core. For an 11-year-old’s experiment, he strongly warns against using gasoline and also cautions against mixing salt into ammonia or other household cleaners. Instead, he suggests safer comparison liquids such as 3-in-1 oil, sewing machine oil, motor oil, beer, milk, rubbing alcohol, vinegar, lemon juice, vegetable oil, antifreeze, or shampoo. He notes that anything acidic or salty can discolor or corrode pennies, and that exposing the zinc core by bending, sawing, or cutting the penny will make corrosion happen faster. A later commenter, tivisan ratnamohan, adds that Sprite can also do the job. The thread’s main takeaway is to use safer materials and expect corrosion or discoloration, not true rust.
Q. I want to find out what makes a penny rust?
We are using 5 new pennies and putting them into 5 different things. We have gasoline, soda (coke), glass clearer, fish tank with salt, ammonia
on
Amazon [affil link] with salt in it . My daughter wants to find out which will make a penny rust. She is only 11 years old.
Thanks so much!
Peggy L [last name deleted for privacy by Editor]
– New York
A. Hello Peggy.
No gasoline! 11-year-olds should not be using gasoline in such experiments! She could try 3-in-1 oil or sewing machine oil or motor oil as a petroleum-based entry in her corrosion tests.
And I’d also advise against mixing other ingredients into household cleaners; while I don’t think that salt is dangerous to add to ammonia, in principal it’s dangerous to add things to ammonia or bleach, or to household cleaners containing either.
She could try beer, milk, rubbing alcohol, vinegar, lemon juice, vegetable oil, antifreeze, or shampoo for some additional ideas. If you can bend, saw, or cut the pennies so the silvery colored zinc core is exposed, they’ll corrode quicker.
But actually, nothing can make a penny actually “rust” because rust is “iron oxide”, so only things with iron in them can “rust”, whereas a penny is made of copper plated onto a zinc core). But anything acidic or salty will cause the pennies to discolor or corrode! Good luck.
Q. I just want to know can orange juice, soda (cola), and water make a penny rust?!
I need this answer for my science fair project ASAP, and for my grandmother she wants to know and so do I.
This will mean a lot Thanks!
Kristien B [last name deleted for privacy by Editor]
kristy forever – cleveland, ohio, united states
April 19, 2012
A. Hi Kristy. All of those things can be tested to see if they make a penny corrode. Even water will, but some will work faster.
But note that “rust” is iron oxide, a reaction between iron and oxygen. If you don’t have iron, you can’t make real “rust” — and pennies have no iron in them. But the copper coating can turn brown or green, and if you cut the penny into pie slices, the zinc core can turn white. Good luck!
A. Be nice.
Sprite can do the job.
tivisan ratnamohan
– london, england
Ed. note: Please see our F.A.Q. on this subject
