Need Company to Powder Coat Chair
I have a bent plywood chair that I would like to have powder coated. I've heard that this might be possible, however, everyone I've spoken to over the phone says that the wood will burn up when it's fired. is this true, or ...
do you know of any companies that could do this small job? becca
Rebecca Citron
New York, New York
You can't powder coat anything other than metal. It's an electro-static process and as wood is NON-conductive...
Testu Nagouchi
- NYC, New York
Thanks for joining into the conversations at finishing.com, Testu, where readers like myself and yourself try to help others--and in the process of trying to help, we sometimes learn as well as teach. As you will discover, your answer on this particular occasion was not quite correct :-)
