Help with antique galvanized bathtub restoration
Q. How do you refinish a galvanized old bathtub and do you put any thing on the inside and what if you have rust inside, what can I do to fix it. I do want to use the bathtub. Help, please.
Deb Harrington- Ottumwa, Iowa
Galvanized Bathtubs on eBay (affil link)
A. Hi Deb. If it's rusted inside it's probably best to paint the inside. Scrub off whatever rust and scum you can with a scrub brush
⇦ this on
Amazon [affil links] and Spic and Span
⇦ this on
or other strong detergent, and maybe a little powdered pumice
⇦ this on
Amazon [affil links] , then a primer designed for galvanized metal -->
then whatever color paint you want.
RFQ: Hello,
I have an antique zinc bathtub that has holes in the bottom of it. I am looking for anyone who can lead me in the right direction to get it repaired. I live in California but am willing to send it anywhere and pick it up.
Any help would greatly be appreciated.
- Los Angeles, California
This meeting place welcomes Q&As, photos, history, & interesting tidbits 🙂
Please engage with other posters
• When people show interest in each other's situations, the forum quickly becomes a fun & informative learning experience for everyone !
• But if posters show little interest in other people's situations, it can deteriorate into a string of unanswered questions
Q. I also have an antique galvanized bathtub on cast iron legs that needs refinishing.and would like to know the best way to approach restoration.
Also would like to trade photos of my tub with others.
Jim Lanier "World Famous Plumber"
Plumber - Tulsa, Oklahoma USA
Ed. note: We'd be delighted to post your photos here, Jim, and post anyone else's as well! Please attach them in e-mail to mooney@finishing.com so all readers can see them; but this is a public forum and we don't offer private matchmaking ( huh? why?)
Q. We too have an old galvanized bathtub on legs. It has peeling white paint on it. Thought an auto body repair shop might strip it and repaint it...might be very cool.
Does anyone know the era of these tubs?
- Dexter, Michigan, USA
Q. I hope you can help me from making a mistake. I am in the process of restoring my grandmother's farm house (built in 1868) and have questions and need answers. I would like to install an antique cowboy galvanized bathtub (with an oak rim) which is a little rusted. How do I arrest the rust with out discoloring the galvanized metal? I've read "lemon" will discolor the metal. Do I use Naval Jelly? I have also found out that the tub will continue to put off (on the surface) a dusty powder to the touch, can I eliminate this discharge? the original tub(s) were left with the galvanized metal exposed. Would it be a mistake to paint the surface, and what kind of primer and paint do I use? I thought of using "auto" paint, applied by a auto body shop, ya or na? My last question is if the seams leak how do I repair this problem and with what materials?
Looking forward to hear your advise.
Home restoration questions - Sisseton, South Dakota, U.S.A.
June 3, 2010
A. Try 5-10% ammonium citrate solution (50-100 gm citric acid ⇦ this on eBay or Amazon [affil links] /1 lit water+add some ammonia ⇦ this on eBay or Amazon [affil links] +pH must be 3,5 for rusted spots, or 7 for galvanized surface).Solution for iron must be used on iron and second solution must be used on galvanized parts.Instead that you can use WD 40 or Balistol (oil based rust removers)+lot of elbow grease.Hope it helps and good luck!
A. If you can separate the tub from any other components (wooden trim etc), then I suggest you get it re-galvanized.
This will arrest the rust, and likely seal any leaky seams (unless gross gaps), and you'll end up with a newly galvanized finish. If you want to accelerate the aging after this (it'll be shiny zinc initially), there are ways to do that explained elsewhere on this forum.
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
for Engineers, Shops, Specifiers
avail from Amazon
"User's Guide to Hot Dip Galvanizing for Corrosion Protection in Atmospheric Service" by NACE (1997 only rarely avail.)
RFQ: Does anyone know of a re-galvanizing company/person in the area of South Dakota, Nebraska and west of these states? I would appreciate feed back ASAP
Betsy Klimmek [returning]- Sisseton, South Dakota U.S.A.
July 10, 2010
A. Ms. Betsy
I agree with Geoff.
There are no galvanizers in South Dakota. There are several in central and eastern Nebraska including: Hastings, Atkinson, West Point, McCook, and Valley.
RFQ: Is there anyone near the Kansas City, MO area that can repair an antique 1800's galvanized cowboy bathtub? The fixture is newer, but the drain is original. There is a large 1'x1' fiberglassed patch job on the bottom and in order to cover up the rust and patch job they painted the outside of the tub and glazed the inside. The cast iron feet, drain, and oak trim are in excellent condition.
Jackie Schwab- Kansas City, Missouri, USA
June 25, 2019
RFQ: Wondering if you found anyone in the KC area as I just acquired one of these tubs that needs some attention as well.
Kelley Cummings- Fort Scott, Kansas
July 10, 2019
Q. I've got an old metal baby bathtub with white enamel that is chipped in various places. What is the best way to resurface this so it will be durable and long lasting?
Teresa McFarlanf- Lone Pine California
November 18, 2020
A. Hi Teresa. The original finish was probably vitreous enamel (porcelain enamel) which is essentially melted glass rather than paint, and something a consumer won't be able to do. Unless you can afford a professional restoration, proper preparation and priming, followed by an appliance enamel appliance enamel is probably the best you can do.
