Thread 545/63
Looking for Spiral Contractometer
RFQ: Greetings,
We are developing a high speed near zero stress nickel electroforming bath. As such our method of measuring the stress in the bath does not translate easily into Pounds per square foot, however a Brenner-Senderhof Spiral Contractometer does.
My question is Where can I get a contractometer?
I thank you in advance for any help I receive.
Anthony J. Coveyelectroformer - Corona, California
publicly reply to Anthony J. Covey
A. A spiral contractometer is a slow test. The same plating solution at the same temp with the same coil, stripped and prepped can easily give data that is 1-2000 different. Two people testing a split sample on different equipment will rarely get the same answer. I bought mine from Kammaras, years ago. King Corp, Larry sells one also.
Quality Control Instruments in Oak Ridge, TN sells a modified one based on a Boeing patent. While I have never used one, but from having my hands on one, This looks like it would be considerable easier to load, calibrate and operate. If I were to do it again, it is the way that I would go.
publicly reply to James Watts
RFQ: To James Watts-
I, too, want one of the easier to handle contractometers. I tried to contact Quality Control Instruments in Oak Ridge, TN and the operator told me "no such place". Do you have a number?
Jeanne KitazakiUnited Airlines - San Francisco, California
publicly reply to Jeanne Kitazaki
The units in question are now offered by QCI's successor, Industrial Instruments Inc. in Newport News, Virginia.
publicly reply to Ted Mooney
RFQ: We use spiral contractometer to measure stress of coatings plated in our Ni sulphamate baths. We used to buy spirals and contractometers from Industrial Equipments. I do not know what happened but phone numbers of Industrial Instruments Inc. are no more valid and they do not reply emails. Can someone suggest another supplier for spiral contractometers.
Thank you very much
Murat Celikaksoy
Plating Shop - Montreal, Quebec, Canada
publicly reply to Murat Celikaksoy
Ed. note 2007: Health issues temporarily impacted their ability to be aggressive in notifying people of their relocation. You can reach them at Phone: (423) 626-6144, Fax: (423) 626-6155, e-mail: Industinst@aol.com.
RFQ: Where can I find a spiral contractometer? Or even parts for one?
Doreen E [last name deleted for privacy by Editor]Quality Control, buyer - Cleveland, Ohio
publicly reply to Doreen E
A. They are now offered by Material Testing Technology, Wheeling, IL.
Robert Szokolay- Clermont, Florida USA
May 10, 2013
publicly reply to Robert Szokolay
RFQ: We are looking for a spiral contractometer for determination of stress in electroplated nickel from sulfamate Ni plating baths.
Satish JalotaElectroplating - Santa Clara, California, USA
publicly reply to Satish Jalota
RFQ: I am looking for either a spiral or gearless contractometer (preferred) for purchase.
Heinz WeberLanding Gear overhaul - Oakville, Ontario, Canada
January 8, 2008
publicly reply to Heinz Weber
Ed. note 2008: Please try Industrial Instruments.
RFQ: I want to buy GEARLESS CONTRACTOMETER, but I don't know how to buy, and which company supplies this kind of product. I'm from China.
Spancy Zhaoauto parts - Shanghai, China
December 2, 2008
publicly reply to Spancy Zhao
RFQ: Hi all,
Very informative thread indeed.
We are looking for contractometers, but it seems QCI, or Industrial Instruments are not contactable at the moment.
May I know if there are other companies selling helical type contractometers?
Thank you!
- Kembangan, SGP, Singapore
April 3, 2009
publicly reply to Jerry Lin
A. Hi, Jerry. Although ASTM B636 is based on the spiral contractometer, and we wish it were otherwise, my understanding is that spiral contractometers are presently unavailable unless you find a used one.
However, there are some alternatives, including: "StressTabs", a serrated Hell Cell panel lacquered on one side so that you can judge the stress at different current densities from the warpage of the various prongs; and the dual bent strip deposit stress analyzer. Good luck.
March 11, 2011
RFQ: I cannot find a company that sells the Brenner-Senderoff spiral contractometers any longer. Can you help?
Cheryl Lewis- Cleveland, Ohio
March 14, 2010
publicly reply to Cheryl Lewis
A. Hi, Cheryl. Spiral contractometers are a very small volume specialized item and to my knowledge were supplied for the last decade or more only by a 2-person company (Industrial Instruments Inc.) which is no longer in business. I do not think they are available at all. I would be happy to hear otherwise.
Stainless steel replacement strips/coils are available from Larry King, Rosedale, NY. Larry King offers some alternate devices for stress measurement, as does Specialty Testing & Development, York, PA.
March 2010
Ed. note May 2013: Ted's mention of unavailability is now dated info; see posting above from Robert Szokolay, and posting below from Nancy Kamka and Dianne Gibble.
A. Ted is correct, you just can't buy a spiral contractometer anymore. You can try to find one used from a plating shop that closes. If you can find one, a much better contractometer was a gearless spiral contractometer (also no longer available) from Industrial Instruments Inc, formerly QCI. They were much easier to use and were more reliable. The Brenner-Senderoff spirals that you can still get from Larry King work in the gearless as well. Of the other ways to measure stress in nickel, the next best is probably the bent strip method that you can get from Kocour. The test is accurate enough, but it is difficult not to deform the strip when you are loading it into the test block. Good Luck.
Jon Barrows, MSF, EHSSC
Independence, Missouri
March 16, 2010
publicly reply to Jon Barrows
A. MTT Material Testing Technology manufactures these spiral contractometers. You can contact us here:
www.mttusa.net
- Wheeling, Illinois
May 15, 2012
publicly reply to Nancy Kamka
A. If you are looking for a Spiral Contractometer or Helix/ Spiral Specialty Testing & Development has Spiral Contractometer equipment for sale that meets ASTM standard B636.
Diane GibbleSpecialty Testing & Development Company Inc. - Seven Valleys, Pennsylvania
October 20, 2016
publicly reply to Diane Gibble
