Enthusiasts helping each other -- No cost, No registration, No damn popups
  Thread 429/81
Metal plating cost calculation
Q. How to calculate electroplating cost?
Andy
- Jaipur, India
December 22, 2024
publicly reply to Andy
Tip: This forum was established to build camaraderie among enthusiasts through sharing of tips, opinions, pics & personalities.
                The curator & some of the readers who publicly share their info are unlikely to engage with posters who don't.
A. Hi Andy.
In addition to this thread which you posted your inquiry on, we have at least 4 other rather long threads on the subject.
  â€˘ Thread 25603 about Zinc Plating
    â€˘ Thread 43852 about Nickel Plating
      â€˘ Thread 53013 about Gold, Silver & Jewelry Plating
        â€˘ Thread 23629 about General Issues
If you need help after reviewing them. please introduce yourself (student, buyer, plater, regulator, etc.), your situation, the type of components, substrate, type of plating, etc. You're not likely to make a lot of progress by simply starting over with an abstract question  đź™‚
publicly reply to Ted Mooney
Q. I'm a Brazilian chemical engineer in charge of a galvanic zinc plating line, and I must find out how to calculate precisely the zinc plating process cost based on A/dm2 (or A/sq. ft.) Most of our local companies charge the service based on the weight of the finished pieces, which is a rather empirical and imprecise way. Does anyone know some kind of software or spreadsheet that could help me on this quest?
Process specification: Rotary, 20 kg, acid zinc based on potassium chloride, without ammonia ⇦ this on eBay or Amazon [affil links] or cyanide.
Dirtiness kind: Several base metals contaminated with oil or grease.
Applied layer: 20 microns
Finishing: Trivalent passivation.
Top-coat: Synthetic resin with water solvent
Thanks for the attention.
Marc Dal'luce
Plating shop employee - SĂŁo Paulo, SP, Brazil
publicly reply to Marc Dal'luce
A. Short of a fairly impressive 3D measuring machine slaved to a computer, I doubt you can find a piece of software that make it much simpler than just setting up your own in Excel. There is a file in the Library here that shows the formulas for most simple shapes ... breakdown your parts into combinations of these shapes and start measuring.
There are a couple of letters in the archives that pertain to the same issue - and that may tip you off to a simpler method - but I believe all the advice breaks down to what I said.
Jim Gorsich
Compton, California, USA
publicly reply to Jim Gorsich
A. ELECTROPLATING DATA BASED ON 100% CURRENT EFFICIENCY IS AVAILABLE ON ANY ELECTROPLATING BOOK.
EXAMPLE WT. PER SQUARE FOOT OF 0.001 INCHES OF DEPOSIT IN GRAMS FOR ZINC IS 16.6 GMS
COST OF CHEMICALS,ELECTRICITY, LABOR COST, ETC., HAS TO BE WORKED OUT.
THANKS AND REGARDS,
ajay raina
Ajay Raina
Ludhiana, Punjab, India
publicly reply to Ajay Raina
A. First things first, measure the area of your current products. You can use Autocad, and model the products in 3D, then the software can calculate the area.
Then start to measure production, how much are you spending for each dm2 worked and for each micron of metal deposited (remember that whe you cover a metal, not only is the area you cover but the thickness of the deposit, which will require energy and time of your equipment).
Saludos
Guillermo Castorena G.
Jobshop - San Luis PotosĂ­, MĂ©xico
publicly reply to Guillermo Castorena G.
A. Hi Marc Dal'luce,
To add up to what Guillermo said, I would like to mention that Autocad is a simpler method to solve your concern. When you make the profile in cad, use a Pedit command and close the loop. Also extrude the same where you mention the thickness. This becomes a solid section. Use a Matprop command and you get the Total surface Area. Just to verify you can also mention density and you will find that you get the exact weight also which you can check on the part also.
But for your information, in cases like Zinc, it is that the conversion cost is higher that the material cost. So better to look at how you can ask the supplier to reduce on time rather than directly negotiating on price in line with Surface area.
Good Luck.
Sanjeeva [last name deleted for privacy by Editor]
Supply Chain - Bangalore, India
publicly reply to Sanjeeva
Multiple threads merged: please forgive chronology errors and repetition  đź™‚
Q. Hi there,
I have recently joined a company as Works Manager that produces strip and wire formed components as well as some dye casting and the plating thereof.
The company has been around for 40+ years now and I have been given the task of solving the age old costing problem around plating with a focus on Zinc. This is all new to me as I am from Textiles.
Our formula is as follows: Zinc Metal 12-15 g/l, Sodium cyanide 24-30 g/l, and Sodium Hydroxide 70-90 g/l
We plate small items like nails, buckles and coat hanger hooks, etc.
Could someone help me with calculating the usage of chemicals per kg plated? or any other advice to get to an accurate RM usage per Kg?
Stuart Aitken
- Sacks Circle, Bellville South
February 13, 2010
publicly reply to Stuart Aitken
A. 1.Analyse the plating bath constituents (Metal,Cyanide & caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] ) and adjust to your formula mentioned in your letter.Tabulate.
2.Adjust additives to get your standard result.
3.Take production of a calculated quantity say 100 Kgs
4.Analyse and arrive at the qty. of constituents consumed.
5.Note down the qty of additives during this period.
6.Calculate as per cost of the additives
7.Calculate the electricity consumed.
8.From the plating cost of 100 kgs,you can derive at the cost of 1 kg.
Please remember about other costs such as labour, rent, office expenses, etc.
t k mohan
T.K. Mohan
publicly reply to T.K. Mohan
A. For accurate calculations you need to know the surface being plated and the thickness. According to this all dosing amounts per Ah and therefore re-calculated on the parts. As well an complete analysis of your production must be done to have also an accurate number of labour, tooling costs and energy costs.
Best regards
Dominik Michalek
- Sydney, Australia
publicly reply to Dominik Michalek
A. Stuart
I would use an amp-hour meter if you are not already. It is good for surface area plated as opposed to kg processed, such as in a barrel operation. Costs per barrel might be more appropriate in those operations as dragout can be a significant factor in chemical usage. Compare production logs with the additions log.
Willie Alexander
- Colorado Springs, Colorado
publicly reply to Willie Alexander
A. It's good to know the surface area, the average thickness plated, and to get a good estimate of the dragout volume per rack and per barrel in order to estimate the chemical use.
the kg can be converted to surface area if the average thickness of the part is known. To estimate dragout, a common method is to start with a still rinse with clean water and carefully measured volume. Then to rinse 10 racks or barrels in it, mix it, and analyze the solution in the tank. From this you can calculate the dragout volume. With this and the thickness being plated, you can estimate your material costs.
It is usually best to do this test on a solution that does not precipitate in the rinse tank, like and acid dip rinse. In this case you can use conductivity instead of a full analysis if you first make a graph of the conductivity of 0.2, 0.5, 1 and 2% solutions of the acid (it should be a straight line if there is no precipitation).
Typical dragout volumes for racked parts are 1.5 to 2 gallons of dragout per 1,000 square feet. For barrels, it varies with size of the barrel, but numbers in the 0.25 to 0.5 gallons per barrel are common for a 24" x 48" barrel.
This may sound complicated, but it should take < 1 hour. Add the metal plated out, and the difference between the cyanide additions and the amount of cyanide calculated by dragout is how much cyanide is lost due to decomposition.
Lyle Kirman
publicly reply to Lyle Kirman
How to make ballpark cost estimate for general electroplating processes?
Q. I am working on cost model for Powertrain components.Could somebody help me to understand (or refer to a right source of data) how I can make rough estimate of Zinc plating, e-coating, anodizing, chroming and impregnation.
I am looking for some industry standards:
- $/per kg of part's weight or - $/per sq.m of part's surface.
Thanks in advance for your professional assistance.
Tatyana
Tatyana Plotnikova
automotive cost engineer - Detroit, Michigan, USA
June 29, 2010
publicly reply to Tatyana Plotnikova
A. Hi, Tatyana. I've seen estimating handbooks for many different industries, especially the construction industry, but regrettably have never seen one for electroplating services. In earlier times a fakebook like that would be a good enterprise for a semi-retired metal finisher to develop but I don't think there's a sufficient market for anyone to undertake this :-)
I think you'll have to rely on quotes from plating shops or hire a plating consultant to put together such figures for you. Good luck.
A. The auto industry is the last place that this will work as companies will cancel a contract for as little as a tenth of one cent per part. It is a cut throat industry with JIT being a costly driving force for the vendor.
publicly reply to James Watts
A. Tatyana ... Unfortunately for you James and Ted are right. I spent 10 years in the estimating department of a good sized metal finisher. There are so many variables that come into play in job costing that I could probably write several hundred pages on the subject. Maybe I will...if someone would buy it. I can tell you this though....the main drivers of finishing costs are cost of chemistry, the cost of waste treatment of that chemistry and of course labor. They all change depending where the finishing shop is located. The only way to determine what you are looking for is to shop around. After a while you will get a good idea of your costs.
Tim Hamlett
Tim Hamlett, CEF
- West Palm Beach, Florida, USA
publicly reply to Tim Hamlett, CEF
Q. I have heard that there is a software which regulates the plating thickness and also calculates the areas too, does anybody know about it.
Ravi Chandavarkar
Ravi Chandavarkar
plating shop employee - Mumbai, India
October 14, 2013
publicly reply to Ravi Chandavarkar
A. Hi Ravi. There are several brands available, but we don't make commercial suggestions in this forum (why?). Google terms like "electrochemical modeling software for plating". They often involve calculating exact placement of anodes, parts, virtual anodes, and plastic shields to try to achieve a more even thickness distribution. Generally this software is presently for the more exotic needs rather than something you see in many shops.
How to do a quotation?
Q. Hi, good day everybody.
Today I am here because I have a couple of doubts; I got a new job in a plating plant and one of my responsibilities is to do a quotation of the cost to process different pieces.
I have 3 lines conversion chrome trivalent (C.C.T), electroless nickel and stainless steel passivate.
On nickel line I have
Soak cleaner
Electrocleaner
Acid dip
and Mickel
on C.C.T. I have a soak cleaner
deoxidize solution
and finally C.C.T.
on [stainless] steel passivate line
soak cleaner
citric acid ⇦ this on eBay or Amazon [affil links]
sodium dichromate
My problem is I how I can know how much chem I am using on my pieces in the nickel bath; I don't have problems on nickel because the nickel metal is fixed on the metal base, and same with C.C.T.
But how I can know on soak, electro, acid dip, sodium dichromate and deoxidize?
I am processing pieces and doing the respective concentration analysis but the concentration doesn't change. I am pretty sure that my analysis is okay -- so somebody know how I can get these quotations?
Could I have it with the size of the pieces?
Aaron Garcia
- agua prieta, Mexico
September 12, 2019
publicly reply to Aaron Garcia
A. No one can even make a guess until you get some basic information together. Start here:
1. What was the total cost of operating your business last year, including labor, supplies, taxes, insurance, utilities, building, vehicles, and everything else?
2. How many hours of billable work were performed last year?
2. B Divide #1 by #2 = your cost per man hour hour of productive work.
3. What percentage profit do you intend to make?
4. Multiply the answer from #2B X 1 + #3.
5. How many man-hrs will the job require?
6. Multiply the answer from #4 X #5. That is your price for the job. Divide that by the number of pieces to find the charge per piece.
The answer from #6 is good enough for a start. Later on you can adjust for differences in your cost for each type of work.
publicly reply to Jeffrey Holmes, CEF
A. Hi Aaron,
With Passivation, your chemical usage is more "what do we have to dispose of when it gets dirty and how often" than "how much stuff is consumed by sticking to each square inch of part". So insofar as 'dirty' relates to iron coming off each square inch of part, relative to the iron content in the part to begin with, the chemicals are pretty cheap and you could instead, for chemical usage estimating purposes, go with a flat rate based on how often your workload requires tank changes, and then divide that by loads per period and have a starting place to add the rest of the cost on top of. Don't forget to include disposal costs, including labor to actually do the tank dumps.
Operator labor is going to be a huge factor here, and part geometry is important. Parts with threads, deep pockets, blind holes, etc. require more labor for blowing off and inspecting, and many parts require inspection under a microscope, which is a big investment. Parts that can't be processed in a barrel, so that they have to be set up in baskets with separation between them so they don't touch, will have to have additional racking time added.
Then there's Time In Tank. Processes requiring long immersion rather than a 10 minute dip get billed more of course, just for taking up real estate.
Post process testing is another charge. copper sulphate ⇦ this on eBay or Amazon [affil links] vs water immersion is a major time difference for the operator, and an equipment commitment if it is water immersion testing. Those are easily handled as flat-rate, per-lot up to X number of pieces, surcharge.
You can build yourself a quoting tool that takes all these factors into account; my suggestion is to gather the following information:
-history of purchases of all chemicals consumed on the passivation line for a year
-a representative period (like 3 months) of run reports, broken down by process spec
-all your specs, and for the ones that offer 2 options for immersion time, ask the operator which is being used
-history of hazmat disposal charges for passivation stuff specifically, including contaminated DI resin beads
-rental/exchange/resin/membrane fees or whatever applies to your DI or RO system
-maintenance records and equipment purchases/repairs
-software licensing fees, if automated
-government fees for operating various hazmat/water related stuff
-outside testing expenses for compliance and/or contamination monitoring
-your observations from timing how long it takes the operator to do prep, racking, processing, drying, testing, and inspection for different part configurations- each step individually timed; there are wide variations from job to job as to what % of the time is spent on what task.
Look at how this all breaks out. What is fixed and what is directly related to workload. Once the bills are paid, and the operator has his compensation package covered, how much profit do you want to see on each job? The answer should pop out at you once you've got it all laid out in front of you in a spreadsheet.
A bonus of building this spreadsheet is that if suddenly the cost of one item goes way up, you know exactly where to adjust your pricing.
rachel_mackintosh
Rachel Mackintosh
lab rat - Greenfield, Vermont
publicly reply to Rachel Mackintosh
thumbs up sign  Thanks both for your answers. Rachel, I will take your advice to search the history of purchases and see how many parts we worked in last year; thanks for that, hope you be fine, best regards,
Aaron Garcia [returning]
- AP , Mexico
Plating Chemical Usage Estimation
Q. Hello All,
I have been assigned the task to estimate the consumption of chemical utilized in my surface finishing shop.
There is a diverse range of chemical processes in our industry.
How can I estimate chemicals quantity required for the Nickel, Cu & Zn Plating.
syed shah
SHOP EMPLOYEE - PAKISTAN
October 19, 2019
publicly reply to syed shah
A. Hi Syed. We appended your inquiry to a thread with 4 good answers. Please get back to us with your follow-up questions.
"Nickel and Chromium Plating"
by Dennis & Such
ni_cr_plating_dennis%26such
AbeBooks
Q. Dear sir,
My name is Kumar. I am working on bright steel chrome plating. How to calculate chrome plating area, and cost, and chemical consumption, and how to add chemicals. Tell me about it sir
Ravi Kumar
- Hosur, Tamil Nadu, India
June 22, 2023
publicly reply to Ravi Kumar
About/Contact  -  Privacy Policy  -  Â©1995-2025 finishing.com, Pine Beach, New Jersey, USA  -  about "affil links"
