Thorium nitrate or alternate analysis method for hydrofluoric acid and ammonium bifluoride
Q. We currently have a etch facility setup in Mexico. One of the Etch bath is using HF/HNO3 [hydrofluoric acid / nitric acid] to etch Titanium aerospace material. We currently determine HF by using 0.4 N Thorium Nitrate titration. Now, there is no supplier in Mexico carry high purity Thorium Nitrate and others countries wouldn't ship the Thorium Nitrate substance to Mexico because it has a radioactive label on it. Is there alternative titration method available?
Harry Chung
Technology Transfer specialist - Toronto
January 22, 2010
January 24, 2010
wikipedia
Ion chromatography
A. The best way to check your solution would be Ion Chromatography. Maybe you could purchase a used IC for this analysis.
Joe Fox
- Painesville, Ohio
January 26, 2010
ACRONYMS:
C of A = Certificate of Analysis
ISE = Ion Specific Electrode
A. Instead of buying the powder, buy a standardized solution. 0.4 N thorium nitrate is generally available and will not have shipping restrictions or storage requirements. Just make sure you get a C of A to satisfy your aerospace requirements. I don't like the thorium method particularly, but for nitric-HF solutions, I found it to be generally more reliable/accurate/repeatable than any alternative including IC and ISE. Good luck.
Jon Barrows
Jon Barrows, MSF, EHSSC
Independence, Missouri
A. I invested in Ion Chromatography for our Fluoride and nitrate analyses in Titanium etch solutions. Fluoride results elute off the column in 1.5 mins and Nitrate in about 2.9 mins ... so fairly quick accurate analyses can be achieved with consistent results. I suggest visiting someone such as Metrohm who specialise in this apparatus.
Nigel Gill, BSc MRSC MIMF
aerospace - Glasgow, Scotland
January 28, 2010
Analysis for Ammonium Fluoborate
wikipedia
Kjeldahl method
Q. We are plating cadmium on high strength steel aerospace parts out of a cadmium fluoborate bath. The bath consists of cadmium fluoborate and ammonium fluoborate in aqueous solution along with some grain refiner which I believe is predominantly licorice (not a good chemical characterization but the best that I have. The pH is maintained between 3.2 and 4.0. In the past we have analyzed cad to determine the cad fluoborate concentration and use a Kjeldahl reaction to determine nitrogen. I have recently created a problem with additions of ammonium hydroxide.
Does anyone know if I can analyze fluorine or boron and what the analytical procedure is or where I could find it?
Pat Reid
- Costa Mesa, California, USA
A. I have produced favorable results for quantitative detection of FLUORIDES using thorium nitrate titration. You'll have to establish your mathematical multiplier using a known, prepared standard sample. The procedure utilizes nitric acid, total ionic strength adjustment buffer solution and a color indicator that I can't recall because it's been so long since I used it. I believe this procedure is listed in the Metal Finishing Guidebook.
randy fowler
Randall Fowler - Fowler Industrial Plating, LLC
Cleveland, Tennessee, USA
Determination of HF and HNO3 in acid etch
Q. I would like to obtain the procedure to determine the HF and HNO3 content of an acid etch solution. I remember seeing a procedure at a previous company, but the company is no longer doing electroplating. We are starting a new process, and will need to control the concentration of the etch solution. OR, any reference books available?
Patricia Frisch
captive shop - Honeoye Falls, New York
"Analysis of Electroplating & Related Solutions"
by Langford & Parker
langford
on Abebooks
(UTL on eBay)
A. This is a common question in this forum. Go to the search function and use "analysis hydrofluoric" as keywords....it will take you to several strings of possibilities for this analysis.
p.s.: I always have been partial to a thorium nitrate titration.
Douglas A. Hahn
- Crestview, Florida, USA
Ed. note: As Douglas notes, the site hosts many additional threads addressing HF analysis ... but most also favor the thorium nitrate titration.
Need Thorium Nitrate Urgently
RFQ: We are interested in purchasing Thorium Nitrate (Th(NO3)4.4H2O (with 4 molecules of water) for the analysis of a stripping bath containing Chromic Acid-Nitric Acid-Ammonium Hydrogen Bifluoride. Our need is URGENT. We tried Fisher and Merck, but they do not supply the reagent.
Thanking in advance,
Michaela-Angela N [last name deleted for privacy by Editor]
lab supervisor - Tanagra, GREECE
Analysis of fluoride in hard chrome plating without using thorium nitrate
August 21, 2018
wikipedia
Thorium
I'm looking for alternative method of determination of fluoride in (hard) chromium plating bath which will not be based on titration by Th(NO3)4.
Our bath contains:
CrO3: 220-310 g/l
Cr2O3: 2-15 g/l
H2SO4: 1-2 g/l
Na2SiF6: 4-10 g/l
Fe: 2-20 g/l
Cu: none
Marcin Sendecki
Electroplating technologist - Poland / Lodz
Ed. note: Some other highly applicable threads:
- Topic 5912 "Analysis of nitric-hydrofluoric aluminum etching mixture"
- Topic 34536 "How to Do Ammonium Bifluoride Analysis"
