Looking for a Coating Thickness Gauge
RFQ: I'm looking for equipment to measure the thickness of
- 1, 2-layer painting on ABS plastic substrate,
- 2, each layer around 15 micron,
- 3, to a resolution of at least 2 micron
- 4, the surface is curved, but can find areas of 1 cm2 not quite so
Thanks for any info.
Hank
Hank Han- Lausanne, VD, Switzerland
A. Dear hank, There is such equipment on the market. I have tried out but the results are not always correct when I compare it with a destructive method under the electron microscope. At this moment there is not good equipment for your problem in my view. I can give you a hint. Put little steel plates on your products. Paint the product and measure the layer thickness. Good luck.
Jan rijnlakfinishing jan rijn b.v. - goes the netherlands
GARDCO = Paul N. Gardner Co.
A. A good source of film gauges is Paul N. Gardner. [Pompano Beach, FL]. If they do not have it is is probably not worth having.
I use 0-200 mil Quanix 1500 gauge.
Tyrone L. CaleyCaley & Associates - Jefferson City, Missouri
RFQ: I'm looking for a Wet Film Thickness Gauge, that can be imprinted with my company name and phone number. The gauge size is approx., 2 x 3.5" & approx., 1/8" thick and is made of stainless steel. Measurements are printed on all 4 sides.
If more information is needed please respond.
Mark C [last name deleted for privacy by Editor]- Blue Springs, Missouri, USA
RFQ: I am also looking for this product (wet film thickness gauge -- comb and or business card style). Have you found a supplier? Please let me know
[last name deleted for privacy by Editor]- Montréal, Quebec, Canada
