CARC Coating? MIL-STD-171 and 171E
Q. We are a 2 man job shop just getting started on military work and the paperwork is making me DIZZY! I saw a thread a while back on here about CARC coating but I had an additional question. We have a little job to quote that requires a final finish of 5.3.1.2 or 5.3.2.2 . I talked to a plater and he said it was a zinc phosphate coating but E states it requires CARC. When are you supposed to use the revised MIL-STD-171E? ASSIST doesn't have the original 171. I hope I made sense. Thank you for all your help.
Doug Paschall
- Paris, Tennessee
A. The confusion is from a paragraph number identical to a finish number. See Table V of E for Finish Numbers.
Finish No. 5.3.1.2 is DOD-P-16232 [now MIL-DTL-16232 [from
DLA]
], Type M (Manganese phosphate), Class 2, treated with lubricating oil conforming to MIL-L-3150 [now MIL-PRF-3150 [from
DLA]].
Finish No. 5.3.2.2 is Type Z (Zinc phosphate), Class 2, treated with MIL-C-16173 [now MIL-PRF-16173 [⇦ this spec on DLA ] Grade 3 corrosion preventive (MIL-L-3150 oil allowed for very small parts).
The supplemental treatment product must be on the current respective QPL, either 16173 or 3150, available from ASSIST.
Generally, use current specifications in lieu of superseded ones. Note when doing so on the documentation. Occasionally, an unobtainable ECO or lack of a current equivalent necessitates using an obsolete finish to satisfy an old blueprint.
- Goleta, California
RFQ: NEED TO SETUP SMALL OPERATION IN-HOUSE TO APPLY DESERT TAN CARC FINISH TO ARMOR STEEL PRODUCTS THAT I AM TO MANUFACTURE FOR U.S.ARMY. NEED INSTRUCTIONS ON WHERE AND HOW TO START THIS OPERATION TO MIL SPEC.
J. SARLESMFGR - DECATUR, Alabama
