How to strip Powder Coating from aluminum, iron and steel?
I have two steel mesh 3-tier letter trays that I'd like to remove the powder coating from to expose the steel color underneath (and will apply a protective clear coat to the metal after removing the powder coating). I'm wondering what is an effective, accessible, and relatively safe way to remove the powder coating. Thanks in advance!
K Usera
- Cleveland Ohio
September 4, 2021
A. Hi K. Powder Coating is an application method, not generally a different material than paint.
Although this thread speaks of some optimal methods to be used in finishing shops which have access to large vats and special heating methods, if you will be stripping the powder coating yourself rather than sending the trays to a shop for stripping, you'll be using paint strippers available from the hardware store. Just read the labels when you go to the store and decide for yourself whether you feel safe.
You should check the trays with a magnet to make sure they are steel not aluminum before you start though. Good luck!
September 2021
Q. I am stuck with a serious problem nowadays which seems hard to be solved in any efficient manner. The problem is "How to remove powder coating from Aluminum, iron and steel objects?". I hope my query will be taken under consideration as soon as possible.
Muhammad Tariq
Plater - Islamabad, Pakistan
A. Hi Mr. Mhd Tariq
Maybe you can try to use sulfuric acid (98%) and heat up to about 200 °C.
KC Tan
- Malaysia
A. What is the chemical type of the powder coating. Would the use of a hot liquid to remove the coating be suitable?
John Neale
- Halesowen, West Midlands, UK
A. Dear sir,
Your stripping of Powder coating can be solved easily ... You have to dip powder coated parts in the 6 mm mild steel tank insulated with cover on top. In the tank you mix 30% flake of caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] and 70% water heat the solution to temperature 120 °C and immerse the items for 20 to 25 minutes. The coating will strip.
Zainuddin
- Karachi, Pakistan
!! The question mentions aluminum parts also which, if immersed in a hot alkaline solution, may be severely attacked.
Guillermo Marrufo
Monterrey, NL, Mexico
A. Hi. Guillermo is surely right that, while boiling hot caustic may work for steel parts, it will destroy aluminum parts. Methylene chloride (aircraft stripper) is a very powerful stripper, and harmless to most metals, but is really nasty stuff for people to work with. Googles, gloves, and working outside (preferably upwind) would be the minimum measures to reduce the hazard to people.
Easy-Off
easy_off
A. Okay boys and girls this is an "EZ" one; to remove powder coat use oven cleaner this on eBay or Amazon [affil links] and it comes off in 15 minutes.
peter cline
- san diego California
November 16, 2010
thumbs up sign Hi, Peter. Thanks.
This does sound workable for coatings on iron and steel but, again, oven cleaner will attack aluminum and must be watched very carefully; plus I doubt that any shine will be left if that's an issue.
April 6, 2011
Q. Kindly give me some solution of removing powder or plastic coating from mild steel (iron wire)? ... is there any acid or compound who can remove coating without damaging product? I used to remove it by heat but it damages the product a lot. Thanks
chumasu laama
manager - kenya
April 6, 2011
Ed. note: As you see, Chumasu, we appended your inquiry to a thread which may answer your question.
Q. Dear sir. I have 400-500 lengths of aluminum sections, we want to remove the powder coating. We have cemented tanks, so, can we remove coating without heating it, as some one told me that he is mixing some other acid or chemical for making sulfuric more effective? If yes, then please mention; otherwise I have to make M.S. tank so that we can heat and the coating will be removed fast.
m.a.khan
powder coater - new delhi, India
March 31, 2012
Q. Dear sir, please give me the chemical composition of powder coating stripper. Thanks, Amir
Muhammad Aamir
- Karachi, Pakistan
November 13, 2012
A. Hi Mr. Aamir. As previously mentioned, methylene chloride will probably do it, but is toxic & hazardous. Proprietary strippers are available but no one can give you the composition of proprietary materials :-)
Although probably not to your full satisfaction, that question has been asked & answered several times on this page already. So please take several sentences to frame your question in terms of the answers provided. We don't want to run the thread in circles. Thanks!
May 2014
How to strip CED coatings from aluminum
Q. How to strip CED coating on aluminium substrates?
Thanks & Regards,
Surya Narayana
Process Engineer - Tumkur , Karnataka , INDIA
May 14, 2014
A. Hi Surya. I believe methylene chloride, i.e., Aircraft Stripper will do it without harming the aluminum. But it's nasty stuff. There are more environmentally friendly proprietary strippers. Good luck.
May 2014
Q. Hello, is it possible that the Airplane Stripper would also remove powder coating from aluminium motorcycle head covers?
Joseph Fuller
- Canton, Georgia USA
May 29, 2014
A. Hi Joseph. Airplane stripper and dichloromethane are the same thing as the previously mentioned methylene chloride. Yes, it's quite likely to work. But do it outside, upwind, wearing goggles this on eBay or Amazon [affil links] , rubber gloves this on eBay or Amazon [affil links] , and hopefully other protective equipment as well. The EPA has fairly regularly issued warnings about methylene chloride.
May 2014
Q. Hi all
I wanted to know whether stripping of mazak is possible to remove the powder coating from the substrate by using chemical. If so then what are its adverse effects too for the metal like MAZAK. And which chemical is to be used?
REGARDS
Snehal
Snehal Patil
- PONDA GOA INDIA
October 28, 2014
Citristrip
citristrip
November 2014
A. Hi Snehal. Methylene chloride (aircraft stripper) is unlikely to hurt Mazak or any other metal, and it is able to remove most paints and powder coatings. But it is noxious, toxic, stuff as previously mentioned! So please see if local suppliers can offer you a less toxic proprietary product. Citrus based strippers may be able to remove some powder coatings.
thumbs up signHi sir
Thanks a lot for your feedback.
Actually I am new to this finishing line, so always curious to know new things from this area. I will be glad if I get support from you in future in terms of plating also.
Snehal
Snehal Patil
- PONDA GOA INDIA
November 3, 2014
Looking for less toxic stripper for powder coating
Q. Hi, I'm the coatings supervisor for a Tier One suspension manufacturer. We use both a single and dual coat process on our parts over zinc phosphate.
Our QC personnel approached me because of concerns over the chemical used to strip test samples. They were using Kleen-Strip Aircraft Remover, and the fumes were bothersome. When I looked into it we found how just how nasty that stuff is. Is there a less-toxic method for stripping the powder coat without damaging the material underneath? The powers that be would prefer to go that route, but if there's nothing as good, we'll have to bite the bullet and put a fume booth in.
Thanks for your time.
Thomas Gauntt
Coating supervisor - Opelika
February 12, 2015
A. Hi Thomas. Yes, Aircraft Stripper is methylene chloride and it is nasty stuff. There are less toxic proprietary strippers for powder coating, and they work. We can't recommend specific proprietary vendors here though (why?)
February 2015
thumbs up signThanks Ted, I completely understand not recommending specific products. Just the knowledge that there is such a thing is a lot of help, and I'll dig harder and see what I can uncover. Thanks!!
Thomas Gauntt [returning]
- Opelika, Alabama USA
February 12, 2015
thumbs up signThanks.
Suraj kukade [returning]
manufacturing - Pune, maharastra, India
March 3, 2015
Q. Hopefully I'm not repeating an answered question but I'll ask anyway. Those small tight corners that aircraft stripper seems to magically avoid. Aside from blasting (something that's not available to me) how else do you "easily" remove that powder coating. I have slathered stripper on it waited and waited and well... nothing, not even a flat head screwdriver seems to get it. I was thinking of trying muriatic acid to finish the stripping process but having used it on other things I know it's pretty strong. I'm not super worried about the metal as it would only be in there a short time but just an option so maybe I can stop my hair being pulled out.
Steve Clark
- Westbank, bc , Canada
June 29, 2015
Ultrasonic Jewelry Cleaner
ultrasonic_cleaner
A. Hi Steve. If the parts are small and you use an ultrasonic jewelry cleaner this on eBay or Amazon [affil links] with a metal tank, it might vibrate the stripper into those tight corners. But if you keep working with methylene chloride your hair will fall out, so you won't have to pull it out :-)
Seriously, I've never done this and would have some reservations. Don't even consider getting near it without chemical goggles and gloves.
June 2015
July 1, 2015
A. My advice refers to an immersion technique and not a brush on / off methodology:
Dissolving Potassium Hydroxide in methyl Alcohol creates a highly exothermic reaction.
It should only be conducted with the strictest OH&S protocols in place and by competent, chemically aware personnel.
That said:
The resulting solution lends itself to stripping Powder from Aluminium.
Take every precaution with this procedure.
Do not leave the stripping unsupervised.
Hope this helps.
Bill
William Doherty
Trainer - Newcastle, NSW Australia
thumbs up signThat's awesome, thanks guys for some ideas I might try the ultra sonic thing first as it looks fairly cheap to try and I could use it for other stuff anyway. If more chemicals are required then yeah I might give the other one a shot, safety first though, I enjoy my skin without bubbles and burning lol.
Thanks again.
Steve Clark [returning]
July 1, 2015
Dear Sir,
Powder coating material not removed completely, so given some suggestion and tell me chemical formula.
Thanks and regards,
Kumaaran Angaiyan
stripping chemical supplier - Chennai, tamilnadu, India
November 5, 2015
Q. I was wondering about stripping the powder coat of a knife that I have recently bought. It's 5160 High Carbon steel. I am leaving the tang powder coated just want to strip the blade. I've seen a few videos on youtube but thought perhaps there were other suggestions. Thank you in advance
Eric Rosbottom
- Yellowknife Canada
November 10, 2015
A. B17 is used to strip powder coat from alloy wheels in 30 seconds to a minute with no damage to alloy, aircraft stripper just softens it you need to then scrape it off.
Jason East
- london UK
December 18, 2015
thumbs up signThanks Jason. Yes, Benco B-17 and Kleen-Strip and other proprietaries are probably better than generic aircraft stripper (checking the SDS tells you that B17 is dichloromethane/methylene chloride based). There are many proprietary strippers; some are more environmentally friendly than methylene chloride, or less toxic to people, or more effective in one way or another.
But we'd rather avoid brand names (why?)
December 2015
Q. Can anybody tell me the formulation of powder coating stripper (Hot method and Cold Method)? Now I am using Methylene Chloride but I want more quick and effective result.
Will the solution of H2SO4 and caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] with providing the 80 °C temperature give better result or not?
Can anyone guide me?
Muhammad Azeem
- Lahore, Punjab Pakistan
May 19, 2017
May 2017
A. Hi cousin. Hopefully we are just having a language difficulty and you are not proposing mixing H2SO4 and caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] -- which would would achieve nothing because they neutralize each other, but which would be very dangerous because of the heat of reaction.
- KC Tan suggested 98% H2SO4 at 200 °C, although that temperature sounds incorrect to me.
- John Neale noted that you need to tell us the type of powder coating (polyester, epoxy, nylon thermoplastic, etc.)
- Zainuddin suggested 30% caustic soda at 120 °C
- Guillermo warns that you must tell us the substrate because caustic soda will destroy aluminum parts, and you must mention the substrate material.
- I suggested, for the aluminum parts, methylene chloride, which you already have experience with; and for tight corners I suggested considering ultrasonic agitation.
- William Doherty offered what he called a very dangerous but effective mixture of potassium hydroxide and methyl alcohol.
- Proprietaries were suggested, and there are many suppliers offering such, which you can google.
At this point I think you need to answer the open questions regarding powder coating type and substrate material, and whether you can consider proprietaries, to see if that leads the readers to steer you towards any of the several approaches already listed, or any additional ones. Good luck.
Q. Respected Sir,
I have TGIC powder coated aluminium frames, which are giving me health problems because of the toxicity of the component called TGIC. I want to remove the powder coat from aluminium frames, but the frames are now fixed and of large sizes, so the removal of powder coat can only be removed at the home. Please suggest an easy way to remove the TGIC powder coat. It's a life and death situation for me. Thanks.
Aman Gupta
- Hamirpur, Himachal Pradesh, India.
May 28, 2017
A. Hi Aman. Have someone with a portable abrasive blaster come in and do this for you, or have someone remove it with sandpaper.
September 2021
Q. At what temperature and for how long does it take to burn off Powdercoating on aluminum rims?
Byron Ness
- Abbotsford bc Canada
November 13, 2018
A. We use a plastic media blaster (sand blaster but with plastic media) set at about 40 PSI. Higher PSI tends to fog the finish on the raw aluminum underneath the powdercoat.
Dennis Kelvey
Advanced Surface Finishing, Inc. - Westbury, New York, USA
February 15, 2019
Q. Hi there - We have some very large aluminum parts that are welded together. We need to remove the powder coat on these parts so we can inspect the welds. Any recommendations on products and processes we can use to remove the powder coating without damaging the welds?
Jordan Burt
- Bozeman, Montana, USA
March 26, 2019
A. Hi Jordan. Aircraft stripper is for removing paint & powder from aluminum. It doesn't damage the welds, but it is noxious & dangerous. There are proprietary strippers that will also do the job, but we don't suggest specific proprietaries (why?)
As others have suggested, mechanical removal is also a possibility, and perhaps the best. Good luck.
April 2019
A. Powder coat removal:
Use plastic media, it works the best. Most people try to use sand media; that will take a long time.
Bob cheek
used to blast oxygen tanks without damage - St george, Utah
May 15, 2019
Even aircraft stripper won't remove powder coating
Q. Hello, I am trying to remove powder coating from fuel pump on Volvo motor on my boat, I tried several strippers including aircraft, nothing works. Need help because paint flakes after time and blocks screen.
Igor Yakush
- Fenton, Michigan, USA
July 27, 2019
A. I think you need to look for powder coat stripper, specifically a gel if you're using it on vertical surfaces. I use Powderstrip PS1, and they do offer a gel that works very fast.
Ian Penedos
- New Jersey, USA
July 31, 2019
thumbs up sign  Thank you I will try to find it; I will update if my problem is resolved.
Igor Yakush [returning]
August 2, 2019
Q. Can you buy this product in small amount, I only found smallest in 5 Gal and I do not need this much. Thank you.
Igor Yakushenko [returning]
- Fenton, Michigan
August 3, 2019
August 2019
A. Hi Igor. See if you can find "plating supplies distributor", "powder coating supplies distributor" or something like that in your area. These organizations often try to meet customers' needs by splitting shipments, re-packaging if authorized, etc., in the wholesale vs. retail model.
sidebar notes
Readers: We usually don't post suggestions of brands/sources (why?). Although Ian tried to help Igor, you see the problem as it develops. It's encouraging a Kleen-Strip vs. Benco B29 vs. PowerStrip PS1 debate which we consider silly (just like Ford vs. Ram vs. Chevy truck, and Mac vs. PC debates). And to answer Igor's question properly, our advertisers (who are making this site possible for you) would now have to pay not just for this recommendation of their competitor but also the posting of detailed info about that competitor's distributorship arrangements, etc. Meanwhile we've encouraged spam, as other vendors now want to post that their stripper is just as good or better than PS1 but is available in smaller packages :-)
Please believe us that with robots scanning our site for spam opportunities 24/7 at computer speed, and with people being paid to post whenever those opportunities are discovered, we receive hundreds of spams every day, and there's just no way to tell actual satisfied customers from shills. Technical suggestions are almost always interesting, but recommendations of a specific proprietary from a stranger on the internet not so much :-)
