Need Aluminum Ion Vapor Deposition Service (IVD)
Current RFQs are posted on our Hotline public forum page
The following outdated RFQs are maintained only for any informational value about applicable processes, parts, and specs.
RFQ: I am quoting some jobs for a customer and am trying to find a shop that does "Aluminum Vapor Deposit". Can Someone help me, I've never even heard of this.
Bill M [last name deleted for privacy by Editor]
- Wilmington, Massachusetts
"Handbook of Physical Vapor Deposition (PVD) Processing"
by Donald Mattox
mattox_pvd_2010
AbeBooks
RFQ: Hi,
I am looking for a business that can perform an Ion Vapor Deposited Aluminum Coating per MIL-C-83488.
Material to be treated -- 4340 Steel COND C SAE-AMSS5000
Heat Treat to 150 KSI UTS Rockwell C 34-38 per SAE-AMSH6875
Parts will be shot peened
**Apply Aluminum Coating per MIL-C-83488, Class 1, Type II. Do not plate holes**
25 pc 1.25" x 2" x 8.25"
25 pc 1.5" x 2" x 15.75"
25 pc 2" x 2" x 10.75"
Each Part will have 3 holes ranging from 3/8" to 15/16" and the holes are not to be plated.
Anthony P [last name deleted for privacy by Editor]
FAA Repair Station - Newberry, Michigan, USA
RFQ: I am looking for vendors to bid on IVD aluminum coating per MIL-C-83488 (or equivalent - spec is actually updated, it is now MIL-DTL-3488, but I can get by with out certification to either of them). I have 234 Sleeve Bolts that are approximately 3/8" dia. x 7/8" long each. Thank you for your consideration.
Andy D [last name deleted for privacy by Editor]
contract manufacturing - Barrington, New Jersey, USA
October 14, 2009
The above outdated RFQs are maintained only for any informational value about the applicable processes, parts, and specs.
