I need a patina finish on a steel spiral staircase
I am seeking a finish that will make an interior steel spiral staircase look patina-like with shades of brown....what finish and/or acid coat do you use to accomplish this?
PLEASE HELP ME ASAP !
Pam McCroskey
- Denver, Colorado
Goran Budija posted this one awhile back regarding another issue regarding protection of galvanized roofing in letter 34208.
"You can use 20 gm tannic acid this on eBay or Amazon [affil links] /15 gm phosphoric acid/1 lit water solution (this is simple and cheap rust converter this on eBay or Amazon [affil links] ). You must lacquer or wax it!"
Marc Banks
- Elizabeth City, North Carolina
You can use next solution(reddish brown):
15 gm iron chloride
1 lit water or pure alcohol
Paint it(or spray) on well degreased object.Repeat if need.Wax or lacquer it.
