  Thread 342/23
Need mass finishing machine for valve plates, spring plates
Q. We are manufacturers of valve parts and spring parts. For the surface finishing we require suitable mass finishing machines. We require guidance from the experts of this machines manufacturers for achieving best results.
Mr.Manan
- Nasik, India
publicly reply to Mr.Manan
A. Valve plates and spring parts can be finished in mass finishing to achieve deburring at edges and polishing.
Many companies use this method but you would need a good supplier to suggest correct media and compound so that parts do not stick to each other.
PRASAD GOGATE
- Thane, Maharashtra, India.
January 8, 2018
publicly reply to PRASAD GOGATE
