Boron Carbide Coating for textile spinning rings
Q. We are a manufacturer of Textile Spinning & Doubling Rings. These rings are made up of SAE 52100 Grade Bearing Steel. We have come to know that some of our competitor is using Boron Carbide as coating on their rings. Is it possible to coat Boron Carbide on Bearing Steel (100Cr6).
Kindly advise.
Prasham Kothari
textile machinery spares - Surendranagar, Gujarat, India
A. You said you knew your competitor is doing it, so you know it it possible :-)
Look into PVD [physical vapor deposition] or CVD [chemical vapor deposition] technologies.
Guillermo Marrufo
Monterrey, NL, Mexico
A. Boronizing is also a surface treatment -- but it's a high temperature, long cycle time oriented process.
If you are looking at this process for just increasing the wear resistance, I would rather look for alternate coating with materials like TiN [titanium nitride], TaC [tantalum carbide] or VC [vanadium carbide].
However, cost could be a factor based on the process employed like CVD or PVD or TRD [thermoreactive diffusion]
I suggest that you can elaborate your end requirement and the target costs -- that would help in the right process selection.
Neelakantan Margam
- Chennai India
March 7, 2008
One of the first successful applications of TRD in Japan was in the textile market, with an application similar to rings.
Dr Jeff Ferreira
- Johannesburg, Gauteng, South Africa
March 27, 2009
Ed. note: For further info please see letter 18074 "TRD [Thermoreactive Diffusion] Carbide Coating"
thumbs up signSorry to stay away from this page for long time...
Yes cost is a big issue as this product is sold in excess of 20-30k pieces every month. So unless the cost is within 20-30 INR... It wouldn't be viable.
Prasham Kothari [returning]
September 24, 2009
