What to use to etch copper, brass or base metal
I am trying to etch Metals such as copper, brass or base metal. I am trying to etch old plumbing parts using stickers as a template. I know NOTHING about chemicals or such. WIll glass etching solution work? I also wondered if there were something less expensive.
Patti Meadows
Herbal Blessings - Chattanooga, Tennessee, USA
There is an easier way, high carbon steel stamps. They are commercially available for about 40-50 dollars, and all you need is a hammer and a hard floor. This takes all the harmful acids out of the mix, just stamp towards the inside of the pipe as it will dent the pipe a bit, but it will work fine.
Marc Banks
- Elizabeth City, North Carolina
To etch your plumbing parts you can use battery acid on eBay or Amazon [affil links] . It's a 30 t0 40% solution which you can add water to for a more dilute mix. Cost $6.00 Rinse well after use. Use a non metallic dip tank also, wear rubber gloves on eBay or Amazon [affil links] and apron on eBay or Amazon [affil links] .
Be careful and good luck -- Fred.
Fred Read
- Duluth, MN, USA
