Need zinc plating service
RFQ: We need to plate alkaline/acid zinc 4-5 microns for hardware items for rack plating in Texas. Quantity 300,000 pieces/ month.
Item weight: around 5 ounces.
Item dimension: 30" X 10"
Item is light frame made of 9 ga steel wire
- Texas USA
November 23, 2021
RFQ: We are a supplier of the automotive industry. We are based in Monterrey, Mexico. I am looking for a zinc plating shop for an annual volume of 300 000 parts. These are small parts: 70x22x1.5 mm. If you are located in Monterrey or close to this town, please contact me.
Patrice L. [last name deleted for privacy by Editor]Parts manufacturer - Monterrey, Nuevo Leon, Mexico
Q. Did you happen to get any feedback on this post? We are looking for the same.
Andrew Ponkow- Saltillo, Mexico
May 11, 2015
A. Hi Andrew. Patrice's posting is from long ago; she probably doesn't come back here regularly and won't see your message, and we can't alert her to your posting if her email address has changed :-(
You might try IPS [a finishing.com supporting advertiser], or Mold Finish in Monterrey ... but please post your own detailed RFQ so it will be seen by plating shops looking for work :-)
May 2015
