Thread 329/21
Need G.E. F50TF1 aluminum coating, inorganically bonded finish
RFQ: HELLO FINISHING.COM:
I HAVE A PART WHICH NEEDS TO BE FINISHED WITH A GE AIRCRAFT ENGINES SPECIFICATION, NAMELY F50TF1, AND THE BLUE PRINT CALL OUT IS ALUMINUM COATING, INORGANICALLY BONDED. MY DILEMMA IS TO FIND A SOURCE WHO CAN APPLY OR SUPPLY THIS PROCESS. PLEASE, IF YOU HAVE ANY SOURCE INFORMATION APPRECIATED. OTHERWISE I WILL BE STUCK WITH MACHINED PART WITH NO PROCESSING.
THANK YOU.
Joel W [last name deleted for privacy by Editor]AERO - Torrance, California, USA
publicly reply to Joel W
Q. HELLO SIR/MADAM;
I WOULD LIKE SOMEONE TO TELL ME THE ALTERNATIVE FINISHING PROCESS TO REPLACE ALUMINUM COATING COMPOSED OF ALUMINUM POWDER AND INORGANIC BINDER, WHICH COMPLIES WITH F50TF1, A GE AIRCRAFT SPECIFICATION BACK A CENTURY AGO. SINCE THIS SPEC IS OUTDATED I NEED AN ALTERNATIVE FINISHING. THIS FINISHING WILL BE APPLIED ON 51410 ALLOY, STEEL CASTING PER AMS5350 (BRACKET, GEAR BOX). THE SOLE APPLICATION OF THIS PROCESS SHALL BE TO PREVENT THE PART FROM CORROSION AND RESIST HIGH TEMPERATURE.
BEST REGARDS,
Joel W [returning]AERO - Torrance, California, USA
A. Try the following:
HANSEN AEROSPACE LAB, INC
AE Supplier Code 43116
DANVERS INDUSTRIAL PARK RTE 1
DANVERS, MA
USA 01923
- Runnemede, New Jersey USA
March 18, 2014
publicly reply to P Merk
