Surface Finish Conversions - Metric/ English and Ra/RMS
Q. What I'm unclear on is the ratio of the surface finish. For instance, a 63 microinch finish denotes the maximum height of the peaks and valleys, however, this has to be over some unit of area. For a microinch is linear and surfaces are two dimensional. Can anyone explain the ratio? I would particularly find this useful to convert and interpret metric finishes to English. The second thing I was wondering is the difference between Ra and RMS. Even if someone could point me in the direction of a good resource for this information.
Mike Doylecenterless grinding - Holliston, Massachusetts
A. The actual values for surface roughness can be found in the following standards - BS2634, ISO 2632 and ANSI B 46.1 .
The parameters and procedures for measuring them are defined in BS1134 and ISO 468 [withdrawn]. It is possible that these standards have been revised, my information I have on these are several years old.
I would also suggest that you contact a flange supply company, for all standard flanges are manufactured with surface finishes, and therefore they should have these standards and all relative technical information.
Good Luck
DEON RAUBENHEIMERGASKETS - JOHANNESBURG, GAUTENG, SOUTH AFRICA
A. Here is how I convert 0.1 µm Ra to RMS
1. step one: convert 0.1 µm to microinches
0.1 µm-.004 µin
2. step two: use the formula RMS=Ra/1.11
RMS=.004/1.11 which equals to: .0018 µin
3. step three: Write the result in standard engineering form:
.0018 µin RMS is usually written as: RMS 18
So here is completed plan on how to convert Ra to RMS (and back).
Thanks, Senthil. You apparently copied this from an entry on letter 9524. But that entry has subsequently been corrected :-(
In step 1, 0.1 µm is 3.937 uin, or approximately 4 uin, not .004 uin
In step 2, the relationship is inverted: Ra must be multiplied by the 1.11 factor, not divided by it.
So the correct answer is 4.44 µinRMS.
Still, this is an approximation, not a conversion, since the two parameters measure different things.
A. www.ptonline.com/articles/200403fa3.html
At the bottom of this page is a good description of Ra, RMS, Rz and Rt.
engineer - Philadelphia, Pennsylvania
July 7, 2008
August , 2008
Thanks, Benjamin, that's a good reference/
August 12, 2008
A. Hi,
This is my way of easy calculation...
a) Convert micro inch to micro meter
1 micro inch = 0.0254 micro meter
eg- Convert 64 micro inch to micro meter
64 x 0.0254 = 1.63 µm (micro meter)
b) Convert Ra(roughness average)to RMS(root mean square)
1 RMS = Ra X 40 (approximation)
eg- Convert 3.2 Ra to RMS
3.2 x 40 = 128 RMS (approximation)
Hi, Minn. It may be easy but unfortunately I don't think it's correct :-)
Conversion a is fine, but in conversion b, your '40' seems to be an approximation for '39.4' microinches per micron, but the conversion lacks the 1.11 to 1.25 approximation of the ratio between Ra and RMS
3.2 Ra in microns would be something like 138 to 160 RMS in microinches.
August 2008
Shreenivas Hayagreev- Bangalore, Karnataka , India
June 15, 2009
July 27, 2011
A. Hi everyone.
As per the surface roughness calculations, I find this conversion formula.
I think it is correct method.
If you find any mistakes mean please clarify me.
RMS -- Root Mean Square value in Micro Inches
Ra -Roughness Average in Microns
(1 micron=0.001 mm & 1 micro inch=0.0254 mm)
1 Ra=43.700 RMS approximately
1 RMS=0.02288 Ra
- Coimbatore, India
Q. How/why is Rz 2 = Ra 3.2
Talwinder Singh- India
November 21, 2012
