G. M. THM 400 automatic transmission steel clutch plate finish
I'm rebuilding a G.M. THM 400 automatic transmission. Instructions are to hand sand steel clutch plates to an 8 to 30 microinch finish. Sanding parallel to plate rotation using 120 to 220 grit emery cloth or sandpaper. I've found a table explaining various grits & types of sandpaper, but no data correlating grit to microinches. Thanks in advance for any help or input.
Marcel Servicemechanic - Covina, California, USA
32 is about what you get with a reasonably decent boring operation. A decent honing job should yield about an 8 finish. For a little more info, see question and responses to #26557 on this website
Tom Gallant- Long Beach, California, USA
