Need Coil Coating and Slitting Line
I want to set up a aluminium coil coating plant, I need complete plant, technical know-how etc.
Zakir H. M. [surname deleted for privacy by Editor]
- Kolkata, West Bengal, India
dated_yosem
We are looking to install a coil coating line & a slitting line for aluminum coil; -width of coil 72 cm, -Weight of coil 3 tons, -thickness of aluminum from 0.2 mm to 1.6 mm, -Speed of the line is 40 meters per minutes. The factory will produce aluminum coils that will be used for the industries of aluminum false ceiling & aluminum rolling shutters . We are interested in a brand new line or a second hand line reconditioned like new.
Elie A [surname deleted for privacy by Editor]
Industrialist - Fanar, El Metn, Lebanon
