Extracting silver from silver nitrate solution for school project
⇦ Tip: Readers want to learn from Your Situation
many readers skip abstract questions.
Q. Hello is there any way to recover silver with salt and Steel nail?
Can anyone help me?
Recycler - Kandy, srilanka
July 6, 2021
A. Recover it from what or where? Sorry, I have no idea at all of what you have in mind.
Please set the scene so people can advise what might be involved.
July 2021
Q. I am a electronic recycler
We collect silver plated copper connectors
And we separate silver from copper
I have seen somewhere they were using salt water and steel nails for silver sedimentation.
Recycler - Kandy srilanka
July 7, 2021
refining consultant - Mumbai, India
August 28, 2021
Hi,
Q. Hey!
At school I have to work out how to extract silver from silver nitrate solution
⇦ this on
Amazon [affil links]
, and I have no idea how to do it! Please can anyone help me?! I only have 4 days left!
student - Lytham St Annes, Lancashire, England
QUICKSTART:
When a metal is "dissolved" in a solution, it is in "ionized" form (missing some its electrons).
In the specific case of silver nitrate, the formula for the solution is AgNO3, or Ag+ + NO3-. The solution contains silver ions of "plus 1" charge (they are one electron short of being silver atoms) and nitrate ions of "minus 1" charge. To get those silver ions into the familiar form of metallic atoms (Ag0) requires that, somehow, one electron be added to each silver ion. Trevor Crichton starts us off with two possible approaches:
1. A "less noble" metal (copper being a good example) can be immersed into the solution. In this case, copper doesn't attract and hold electrons as powerfully as silver does, and we have Cu0 metal sitting in a solution of Ag+ ions. So the silver ions start "stealing" electrons from the copper and becoming Ag0 atoms while the copper atoms lose the electrons and become Cu++ ions dissolved in solution (Why copper ionizes as Cu++ instead of Cu+ is a subject for another day). You will see the reaction as the copper object becomes silvery looking from the deposition of silver atoms on the surface, while the solution may turn blue because copper ions are blue. Eventually you either run out of silver ions in the silver nitrate solution, or the copper becomes completely coated with silver atoms; in either case the reaction eventually stops.
2. A "reducing agent" such as the glucose or formaldehyde will supply the electrons for the silver to be reduced as a metal. This is how silver-backed glass mirrors and silver Thermos bottles are made. Google "Brashear process" for an introduction.
3. Chris Dunsmore introduces a third way, which is to supply the needed electrons by attaching a piece of metal to each end of a battery and immersing the pieces into the solution without the two pieces touching. As electrons flow out the negative end of the battery, they will reduce the silver ions to silver atoms. This is called electroplating. As he suggests, this one might be better to read about than to actually do.
4. Arsi Saukkolas suggestion has, as he says, the advantage of being "quantitative", i.e., you can remove all the silver from the silver nitrate and determine how much there was. His suggestion involves sort of the inverse of using a noble metal: you use an anion, Cl-, which grabs the silver more powerfully than the NO3- does, with the result that all the silver goes into the form AgCl in place of AgNO3; and the AgCl doesn't stay in solution, but precipitates and drops to the bottom of the beaker.
A. Firstly, don't leave it so late next time! Secondly, you need to reduce the silver ions to silver metal. This is done with a less noble metal being put into the solution and letting it dissolve. The dissolution process will result in the silver being precipitated out. (Now tell us which less noble metals will do this and how). Alternatively, you can use a reducing agent such as glucose or formaldehyde (very nasty and pongy) and this will throw out silver onto the sides of the vessel.
A. Have a look at letter number 25979, "Recovering silver via electroplating"; that should help you out.
You may want to just read the letter and not actually try to do it as some of the materials needed are not very nice to use.
metal pre-treatment - Leicester, UK
A. The easiest way to extract silver - quantitatively - from silver nitrate solution, is simply adding sodium chloride (table salt) solution. Silver chloride will precipitate and is quite easily decanted and/or filtered. This is probably what they wanted in the first place for you to do. To reduce silver chloride into metallic form is much more complicated. You might wash and wash and wash again the precipitate, then make the reduction with sodium hydroxide and formaldehyde. I do not recommend this to anyone because of the toxicity of formaldehyde.
One easy way is to mix the washed silver chloride into photographic fixer and then electrolyze using graphite anode and stainless steel cathode, to produce silver of 94 to 99% purity.
metals recycling - Espoo., Finland
A. Adding plain copper will work.
Simon Dupay- Roseville, Minnesota
Q. Hi all,
I am very eager to know how would they extract silver from silver nitrate. If the quantity of silver nitrate is huge, e.g., 1000 litres, and the solution is a mixture of other metals like copper, aluminium, etc., how can we extract pure silver from this ?
Can anybody suggest the cheapest and efficient way of extracting silver.
regards,
- Coimbatore, Tamilnadu, India
A. Take the Silver Nitrate solution and add common table salt. The silver will turn to a cottage cheese looking flocculent and drop to the bottom. Filter off the Fluid and neutralize with sodium hydroxide. Then add Sodium Hydroxide slowly and carefully to the flocculent stirring as you go. It will turn the Silver Chloride to silver oxide. Let it dry and then grind it down to powder. Then mix with bonami and smelt in a crucible in a furnace at 1200-1400 °F for 2 hours. Cover the entire mixture with 1/2 inch of Borax on top of the silver oxide/borax mixture.
Once you have complete melt pour into an ingot mold.
Your result will be a very high purity Silver bar.
- Seattle, Washington
A. Cheapest and safest way to claim high purity silver
Hang a piece of pure (99.9% to 99.98%) copper bar. For faster results try copper as anode and pure silver rod cathode.
Please follow the above method for safety and it's cheap, good.
jewellers - Bambalapitiya, Colombo, Sri Lanka
March 22, 2013
Q. So, this site is helpful. But how would I go about extracting silver nitrate from a mixture of sulfur, iron, and silver nitrate? I only have one chance to do it. If I mess up, I'm slightly screwed. Could anyone help me?
Robert Vanity- Bradford, Vermont
March 14, 2008
A. Robert, you haven't given us much context upon which to expand from the previous excellent responses -- and we really need to know whether this is a student project, industrial need, or hobbyist undertaking.
Where did you get this mix and how do you know what is in it? You have only one chance?! Maybe you're a high schooler and this is an experiment/exam? It should be possible to remove the iron from a mixture with a magnet; and I don't think sulfur ⇦ this on eBay or Amazon [affil links] is soluble, so you can probably filter it. Best of luck!
If this is not for an academic requirement, but an actual industrial need, I must completely disagree with your characterization about having only one chance! A chemist never attempts to react an entire industrial quantity batch based on book knowledge, but only after he has first proven his chemistry with small scale samples does he scale the quantities up. (You might include that note for extra credit if you are a student).
If you are a hobbyist, we must warn against the danger of creating explosive silver fulminates (that can explode from simple vibration) if you are fooling with silver chemistry that you are unfamiliar with. Good luck!
March 14, 2008
Q. Hi everyone. I was wondering if anyone could help me with a question I got from school. I'm in grade 10 and this is for science class on the topic of chemistry,
"You work for a company with a large quantity of Silver nitrate solution. The company wants to recover and sell the silver metal. Design a process to recover the silver metal from solution."
Please help me.
student - Toronto, Ontario, Canada
March 1, 2009
A. C'mon now, Carla. Get to the library and study the chemistry of silver nitrate; then propose an idea or question and we'll be happy to help you with its strengths and weaknesses. You're supposed to give this serious thought, not ask someone for the answer. Good luck!
March 1, 2009
A. Hey that is really cool! I have to do that too! What I am going to do is get five different metal strips and put them into the solution to see which one attracts the most silver. You may not have the access to the metals and they take some time to be shipped. you only have 4 days so I don't recommend waiting! That is my only way to do this. Sorry! Maybe it can be of some help to you! My dad is a chemist so that is what he told me to do! Good luck with this! I do hope that you succeed.
Molly k [surname deleted for privacy by Editor]- Batavia, New York
February 18, 2010
Q. Hi ...
Right now I doing a project on recovery of silver, copper, zinc and cadmium from nitrate leach solution by solvent extraction.
When I add sodium hydroxide to raise pH from 0.33, then a large amount of precipitate is observed. Please anyone tell me how I minimize this problem.
Also suggest which extractent I can use as selective to silver, copper, zinc and cadmium in which pH range.
Student - Vadodara, Gujarat, India
April 14, 2013
Kiss of Death
A. Hi Sohil. Yes, it seems to me that if you simply raised the pH you'll precipitate all of those heavy metals together, not making progress. I know less about this than you do, but I do see good discussions above about either precipitating the silver with table salt, or plating it out by displacement onto solid copper.
Please try to frame your question in terms of what has already been offered because it's the kiss of death to potential responses if the helpers feel that someone is asking them to repeat their efforts rather than taking the time to read what they already wrote :-)
Q. Hi all! I am about to begin reclaiming high purity silver metal from a solution of silver nitrate, made from scrap silver and 70% fuming nitric acid, by precipitating with copper. As it turns out, the copper metal can be reclaimed after all the silver is removed by adding aluminum. Does anyone know how is the best way to neutralize the solution for disposal after adding the aluminum? Is it possible to return the nitric acid to a state that will dissolve silver without losing too much volume or potency? I have 1/2 US gallon of acid, and at the end of the process expect to have at least 1 US gallon that will undoubtedly be diluted with distilled water.
- Florence, Alabama
November 21, 2013
Electrolytic extraction of silver using silver trioxonitrate solution
Q. Hi guys. Please can anyone one tell me how I can do this assignment:
Electrolytic extraction of silver using silver trioxonitrate(v)solution.
- Port Harcourt, Rivers state, Nigeria
May 12, 2014
A. Hi Gostime. There should be some context; it seems unlikely that you have no textbook, workbook, instructions from the teacher, hypothesis, warnings, just "Do it!".
But you can take two 2-foot long lengths of copper wire, and coil most of their lengths around separate pencils, then remove the pencils. Attach the uncoiled ends to each pole of a 1-1/2 bolt "D" cell battery and don't let the wires touch. Put the coiled ends into a beaker (again, don't let them touch). Put your silver trioxonitrate solution into the beaker. One of the two wires will turn silvery. As soon as you see some silver on it you have electrolytically extracted silver using silver trioxonitrate solution, and have completed the assignment. Good luck.
May 2014
A. Hi Gostine
After a (very) long career as a professional chemist, I have never heard of trioxonitrate (v)
You will find that you will find the answer more easily if you refer to silver nitrate.
Trioxonitrate is not recognised by the International Union of Pure And Applied Chemistry IUPAC who are responsible for naming chemicals. Using a non-standard name for common chemicals has serious safety implications.
January 14, 2015
Q. Here is my situation:
I would like to precipitate pure (or as pure as possible) silver from a solution of silver Nitrate. My belief in most of these cases is that the solution is mostly pure aqueous silver nitrate.
My first plan: To use clean/non-coated copper wire to reduce AgNO3 into Ag(s) and Cu(II) NO3
I then will test the silver precipitate's boiling pt. to get a general idea as to its purity.
My second plan if there are impurities: AgNO3 + NaCl > AgCl + NaNO3
Then: AgCl + NH3 to make new solution
Is it possible/safe to redox the AgCl and ammonia
⇦ this on
Amazon [affil links] solution with Cu (or similar metal) to precipitate a purer silver?
Should I get in touch with an ICP operator to test the AgCl purity?
I am a facility Chemist in a Haz Waste facility that wants to perform this reaction in order to get pure silver for jewelry making with the goal of working with silver smith to make my wedding rings.
- Burlington, Vermont USA
Q. I will be performing a simple Redox reaction to precipitate silver from AgNO3 using a solid copper rod.
I have two questions.
1. Most copper rods come with some sort of oxide coating. How might I safely and completely remove (either chemically or physically) this coating so as not to precipitate a impure silver.
2. I want to also try removing any trace metals from the silver nitrate solution with sodium chloride. How easy it is to then precipitate silver from AgCl?
January 17, 2015
A. Hi Luke.
1. Sandpaper or scotchbrite should easily remove any coating on your copper rod. Then rinse off the dust with water, and immerse it.
2. You won't be able to remove the trace metals once you've placed the copper rod in it because for each two atoms of silver deposited on the copper rod, one atom of copper dissolves into solution ... and sodium chloride will not precipitate the copper; rather, it will stay in solution.
Oops, I replied to your 2nd letter before I noticed the first :-(
-- so let's see what others have to say.
January 2015
A. Hi Luke
Ammonia can react with silver salts to give a range of highly sensitive explosive compounds.
In a Haz Chem facility you should know this
The simple answer to your question is to simply stir in some (clean degreased) steel wire wool and stir.
A. Whether you use copper to cement the silver or use a chloride to precipitate silver chloride, about the only source of contamination will be the solution mixed in with the solids. The solids themselves are of high purity. The more you rinse these solids, the higher the purity of the silver. Hot water rinses are best.
I would absolutely avoid the use of copper wire for cementation. The cemented silver intermingles with the wire and makes separation difficult. Also, the small wire tends to dissolve and release slivers of copper that contaminate the silver. The best copper to use is bare scrap copper buss bar (say, 1/4" X 2" or 3") that contains no solder and is not plated with tin or silver. Put the silver solution in a plastic 5 gallon bucket and use 5 or 6 lengths of buss bar. The pieces of buss bar should be long enough to stick up out of the solution so you could easily remove them
I would advise against steel wool. It's easy to do but recovery of the silver is more difficult.
All in all, if you want fine silver (at least 999.0 fine) you will have to put the recovered silver through an electrolytic silver cell. Chemically processed silver, no matter what process you use, will not normally meet the accepted 999.0 fineness requirement. There is an oxalic acid process that may reach this purity, but it is tricky.
- Nevada, Missouri, USA
January 18, 2015
A. Please use hydrazine hydrate to reduce silver from silver nitrate solution.
bhupesh mulikCAC admixture - Mumbai, India
February 26, 2015
Q. Good day!
I am a student and research enthusiast from Digos City, Philippines, often spending my time at the laboratory.
Other elements or compounds would do, but in the case of copper, could you help me explain why do silver crystals deposit on the copper coil when it submerges into the solution during the recovery of silver from silver nitrate solution?
I understand about the redox reaction and single displacement happened during the recovery of silver in a silver nitrate solution with copper coil.
Cu + 2 AgNO3 ---> 2 Ag + (CuNO3) 2
In that reaction, I know that copper II ion is what makes the solution blue. But I can't find out what's in copper that makes the silver deposit onto it during the time the copper coil is submerged in the silver nitrate solution. Hope I will be able to get help. Thank you.
Shiina K [surname deleted for privacy by Editor]student - Digos, Philippines
April 1, 2016
A. Hi Shiina. You have written the reaction almost correctly, it is actually:
Cu + 2 AgNO3 ---> 2 Ag + Cu(NO3)2
I'll write it in slightly fuller form here, to include notations about the oxidation states of the atoms and ions:
Cu+0 + 2 Ag+1NO3-1 ---> 2 Ag+0 + Cu+2(NO3-1)2
Cu+0 means the copper is in metallic form as an atom, whereas Cu+2 means it is in ionic form, missing two electrons. Similarly ...
Ag+0 means the silver is in metallic form as an atom, whereas Ag+1 means it is in ionic form, missing an electron.
Actually, there is nothing "in" copper or silver except copper and silver -- they are irreducible elements. But silver has a stronger affinity for electrons than copper (it is more "noble"), so it is capable of "stealing" electrons from copper. So what happens in your reaction is you put copper atoms into a solution of silver ions, and the silver ions steal electrons from the copper atoms, thereby becoming silver atoms, while the copper atoms become copper ions.
Q. Why is Zinc not used instead of copper to refine silver from silver nitrate?
- Cairo , Egypt
June 6, 2016
Q. Hello all.
I am all sorts of confused. I dissolved odd silver items in nitric. when done I added distilled water (1 to 1), then put in a copper pipe. Instantly saw what I thought was silver precipitating. However, when I melted it down and made flakes in a bucket of distilled water, I was shocked to see yellow metal and not silver. Help! What did I do wrong? I still have a half gallon of sharp blue fluid.
Thanks for your help.
prospector - rapid city, south dakota. usa
September 17, 2016
Q. After using copper, how do I extract the copper and then reuse my nitric acid -- is it possible? Or is salt better and how if so do I get it back to nitric acid to make more silver nitrate? Thanks, Eric
Eric M Mullinex- Independence, Iowa, United States
March 25, 2017
A. Hi Eric. Chemical reactions of this sort move in one direction, towards lower energy states -- that's what powers them. We'll see if anyone can offer encouragement about a practical way of putting the necessary energy back in, via heating or whatever, but I doubt it.
March 2017
A. Don't see what's wrong with steel wool.
Let the Ag plate out, dissolve away the Fe with HCl, then melt it down.
Dave Wichern
March 27, 2017
A. Eric, why do you want to reuse the HNO3? Is it because you are trying to save money on nitric? If you can find a decent method to eliminate the copper, the cost will most likely exceed that of just using fresh nitric for the next batch. Although I've been a professional refiner for 50 years, I've never known of a good simple inexpensive method to do what you want to do.
I'm not a fan of using steel wool to drop the silver from a nitrate solution. For one thing, it's almost impossible to leach out the excess Fe with HCl without converting at least some of the silver to silver chloride. After melting the silver, the AgCl will form in a layer between the slag and the Ag and will most probably be lost. Also, AgCl can evaporate at the Ag melting temperature. sodium carbonate
⇦ this on
Amazon]
can convert AgCl to Ag in the melt but, to do so, the particles of AgCl must intimately be in contact with the particles of Na2CO3. Also, this reaction will quickly erode the crucible. The use of steel wool is not necessarily hassle-free.
I've always used copper to cement out the silver. It's very simple, efficient, and hassle-free. One gram of copper will cement out 3.4g of silver. However, if you use an excess of HNO3 to dissolve the Ag, this excess will dissolve copper also and copper will be wasted. Always try to use only enough HNO3 to dissolve the silver, with no extra. With an open top container, it takes about 1.2 ml to dissolve 1g of silver. If the container is covered, it can take a little less HNO3.
For a more thorough discussion of this process and most every other refining process known to man, go to goldrefiningforum.com. I am a moderator there under the name goldsilverpro.
Good luck
- Benton, Arkansas, USA
March 28, 2017
Silver Nitrate And Distilled Water With A 99.9 piece of copper
Q. My 14 year old daughter has a project I'm not sure of. She has 50 grams of Silver Nitrate and Distilled water plus the piece of copper. I'm trying to help her but neither she nor I know the answer to how much distilled water to add to the 50 grams of Silver Nitrate?
She is also supposed to use table salt and bring her final "acquired" silver powder to be melted at school. It's not due until Monday, April 10, 2017. HELP!
Blessings,
- Texas City,Texas/ United States
April 6, 2017
A. Hi Cheri. It probably doesn't matter a real lot how much distilled water she uses, but for extra credit she should look up the solubility of silver nitrate, and use that to justify how much DI water to add. For example, if she finds that the solubility in room temperature water is 2 grams per ml, she can say that she needs at least 25 ml of water to dissolve the 50 grams of it.
If the teacher wants her to show the reaction
AgNO3 + NaCl => AgCl (precipitates) + NaNO3,
where one molecular weight of NaCl precipitates one molecular weight of AgNO3, she can also say that there obviously can be no more than 50 grams of Silver Nitrate left after using it on the copper, and she can calculate how much table salt she needs to add to precipitate it: 50 grams x (molecular weight of NaCl molecule) / (molecular weight of AgNO3 molecule). Good luck.
Q. Ted,
Thank you but she's not strong in science, & Cierra is not understanding the salt part. Iodized or not & she's definitely barely making it in math. She doesn't understand how much salt to add to the Silver Nitrate and the water mixture and when. This extra credit will pass her into the 12th grade. I wasn't advised of this until the last minute.
April 8, 2017
A. Hi again. From the fact that she has silver nitrate (AgNO3), copper (Cu), & DI water, and is supposed to supply table salt (sodium chloride / NaCl) -- and with no other input -- you're asking people to guess what the experiment is about, how it ought to be conducted, what the results are expected to be, and -- most importantly -- what she's supposed to learn from it :-)
If she has no idea what she's doing, and received neither instructions in what to do nor a goal from the teacher, this seems to be a make-work project. Darwin himself said that to go into a gravel pit and sort the stones by size or color with no bigger objective is to waste your life.
As a guess, I think she is supposed to mix the silver nitrate into DI water, immerse the copper into the solution and observe silver plating out onto the copper; and after the plating is done, she's probably supposed to add table salt to the solution to precipitate the silver so it can be filtered out from the solution back in school.
But she has to attempt to learn something, or this is all simply a ridiculous waste of your time & mine. I already suggested some things that can be learned ...
First, she should look into the issue of 'solubility'. If you add several spoonfuls of sugar to your coffee, some of it (maybe one teaspoon?) will dissolve and stay dissolved (the coffee will become and stay sweet), and the rest of the sugar will slowly settle into a sludge at the bottom of the cup when you stop stirring. How much stays dissolved often depends on the temperature of the water. Similarly, some amount of silver nitrate (AgNO3) will dissolve into water and stay dissolved, so I linked to a Wiki article for you that told you the solubility of silver nitrate at different temperatures. Did she see the line that says the solubility is 256 g/ 100 ml at 25°C there? It's grade school math, not high school math, that if 256 g will dissolve in 100 ml, then 50 g will dissolve in 19.53 ml of DI water. So she will need a minimum of 19.53 ml of DI water, which she should explain for credit, and as a practical matter she can use say 25 ml of water to dissolve her 50 grams of silver nitrate and explain why.
The second thing she certainly is supposed to learn is that while silver nitrate (AgNO3) is very soluble in water, silver chloride (AgCl) is certainly not -- that is, silver chloride does not dissolve in water. She can find silver chloride on Wiki and see that its solubility is lower by a factor of about a million! She is probably supposed to add table salt to the silver nitrate and understand that the reaction will be:
as I previously said. If she adds one molecule of table salt (sodium chloride, NaCl) for every molecule of silver nitrate (AgNO3), she will get one molecule of silver chloride (AgCl) which will precipitate, settle out, and be filterable in school (with a simple filter not much different than a Mr. Coffee filter) and one molecule of very soluble NaNO3 which will not precipitate.
The third thing she can learn and is probably supposed to learn is how much table salt (NaCl) will be required. She has at most 50 grams of AgNO3 if that's what she started with, and some of it deposited onto the copper. If she divides this by the molecular weight of AgNO3, she'll know how many gram molecular weights of AgNO3 this means. If she multiplies that answer by the gram molecular weight of table salt (NaCl), she'll know the maximum grams of table salt she could require to precipitate out all the silver so it is filterable. She determines the gram molecular weight of silver nitrate (AgNO3) by adding the atomic weight of silver, nitrogen, and 3X the atomic weight of oxygen. She finds these in the "Periodic Table". She determines the gram molecular weight of table salt (sodium chloride, NaCl) by adding the atomic weights of sodium and chlorine. Good luck.
If this is too much to absorb in one sitting, sorry, but it's not my fault or yours, it's either the teacher's or your daughter's :-)
April 9, 2017
- Texas City, Texas/ USA April 10, 2017 I think plating (if we're talking electroplating) would be better done out of a thiosulphate solution. ![]() Dave Wichern Consultant - The Bronx, New York |
A. While probably not what your teacher is looking for, a silver nitrate solution can be heated (fume hood) until the water boils off, continue heating till around 440 °C, by then the AgNO3 will decompose into Ag, O2 and NO (highly toxic!).
But I think they are looking for a chemical method.
- Newark, New Jersey USA
August 24, 2019
