Making a blued gun into silver looking?
Q. I have an older bolt action .410 gauge shotgun that is tube fed and has a short barrel. I am planning to refinish it and make it a snake gun for my dad. I considered re-bluing it but after sanding on it a bit I think I would like to polish it out somehow to shine somehow.
Can this be done without adding a new finish like chrome?
If so, how can I get it to shine best and resist rust?
Can I add something like a clearcoat to protect the metal and keep it from rusting or oxidizing?
William Harris
- Spencer, Virginia, USA
A. William,
I have refinished several old heirloom pieces like you are describing. It takes a lot of elbow grease and fortitude.
After disassembling the piece, I usually begin by removing the surface rust in a dipping solution I found called Brownell's SteelWhite this on Brownells [affil link] . Follow the instructions that come with the product.
I then start sanding the steel depending on how deep the rust is, with 220 grit wet / dry sandpaper ⇦ this on eBay or Amazon [affil links] . If the piece is really rusty, I have started with 100 grit. I then follow it with the next finer grit paper such as 320, then 400, 600, 800 and so on until I get the desired polish I want. On one piece I took it all the way up to 2000 grit paper. The steel actually looked like chrome when I was through sanding it. Be careful around the stampings not to cut the numbers / make / model numbers or any engraving away. Once properly sanded / polished you can reblue the piece using a cold blue chemical. I recommend Oxpho-Blue this on Brownells or eBay or Amazon [affil links] -- it seems to give the best overall finish. Be sure to degrease using Denatured Alcohol this on eBay or Amazon [affil links] prior to applying the blue. Remember to wear rubber gloves this on eBay or Amazon [affil links] when handling this and any of the chemicals mentioned here. Again follow the instructions that come with the product.
You can also refinish the wood as you would any piece of fine furniture. Be careful to remove the old finish with a good stripper ⇦[this on eBay or Amazon affil links] like Pro-Stripper and remove any old oil stains before you start and remember the finer the grit paper you use, the better the polish. Don't be afraid to take the wood up to 400 grit. For final finish I like using tung oil this on eBay or Amazon [affil links] also found at Brownell's or Walmart in the gun section and applying several coats on the wood to get the best gloss on the finish. You can stain the wood before you apply the tongue oil if you want to change the color. Remember to use an oil based wiping grade stain this on eBay or Amazon [affil links] such as Old Masters and let it dry thoroughly. When sanding watch out not to change the shape of the wood especially around the butt-plate or receiver or anywhere it fits against the steel. And for goodness sakes don't sand the checkering. Use Pro-Stripper and an old tooth-brush to get the old finish out of the checkering.
As an alternative wood finish I have used clear gloss polyurethane, applied several coats, let it dry several days then wet sanded it with 2000 grit paper, then hand buffed it with a good grade of car polish. The finish looks like a glass with a shine so deep you can actually see yourself. I refinished an old single barrel for my father-in-law for his Christmas present last year. He was so impressed that he has the piece on display and has vowed that it will never be fired again.
You can get a near professional refinishing job if you are careful and take your time. On some pieces I have even made the finish look glossier and more polished than the original finish on both the wood and the steel.
Kip McClary
- USA
thumbsdown No offense, but you clearly didn't answer the question. He was asking how to get a "silver looking" finish. He is taking the bluing off and prefers the shiny metal look underneath. He doesn't want to make it look black again.
Benjamin Hargrave
Amateur gunsmith - Boise, Idaho
February 24, 2025
A. Hi Benjamin. If you can tell William how to do what you are describing, please do.
If you are implying that you don't know how to maintain a bright finish on a barrel and other metal gun parts either, but want to, we'd need to know whether the barrel is stainless steel or not. If it's stainless steel, after polishing it as Kip describes, you would 'passivate' it. We have lots of threads on that subject, but don't want this thread to meander off into passivation of stainless steel if your components aren't stainless.
If the parts in question are steel, and not stainless steel, and like William you do not want to plate them, a clear coat or frequent waxing is your only alternative, but you'll only get steel moderately shiny, it will never be the color of chrome plating; and clear coats will be subject to yellowing from heat after a while. If, unlike William, you are willing to have the gun nickel plated or nickel & chrome plated, tell us, and we'll move the discussion in that direction, although nickel-chrome plating is more difficult to do, and will involve a lot of practice and learning if you want to learn to do it yourself, and almost surely using a chrome substitute not real chrome plating. Thanks!
Barricade
birchwood_casey_barricade
Aluma-Hyde
brownells_aluma_hyde
thumbs up sign Thank you for your response. It seems highly unlikely that William was removing the bluing from a stainless shotgun, and he said he didn't want to chrome plate it, so I guess that leaves clearcoat or wax, but there are other cleaning oil protectant products that claim to prevent rust on bare steel, such as Birchwood Casey Barricade ⇨
Q. Do you have any recommendations, either positive or negative? It seems that Brownells Aluma-hyde ⇨br is the only clear coat specific to bare steel firearms that I'm finding available at the moment. Is it likely to yellow like you said? If Barricade works then would it be better to skip the Aluma-hyde to avoid the yellowing effect? If it does yellow, would it be relatively easy to strip it and reapply it? Thank you.
Benjamin Hargrave
March 7, 2025
thumbs up sign Hi again. Thanks for the reality check that darned few shotguns would be stainless steel  🙂
Sorry, I have no personal experience with those two products, so I'd have to leave it to others. We prefer to keep the discussions technical and focused on types of coatings rather than advocating specific brands or sources ( huh? why?) but surely rust prevention products and clear coat products which, like these, are specifically made for guns seem more likely to be appropriate than products which are primarily intended for other purposes.
Q. How do I polish a blued revolver to a mirror finish? I have a revolver that is blue (standard black finish) I want to put a black mirror finish on it so I will have a real nice show gun. How do I polish blued metal on a revolver?
"Firearm Blueing & Browning"
by R. H. Angier
angier_firearmbluing
or eBay or
Robert Kerns
hobbyist - Lilburn
July 12, 2008
A. Hi, Robert. The bluing is exceptionally thin -- not as thick as the amount of material you would need to remove to get to a mirror finish. So you can't polish a black oxided gun, you need to do it in the opposite order: mirror polish, and then have it black oxided again. Good luck.
Q. I have a silver looking finish gun I'd like to make black; all my other guns are black, so I'd like this one to match. I was thinking of bluing it.
It is a Taurus PT92. I believe it is made of aluminum then polished to a shine so it almost looks like it was chromed. The problem is it leaves visible stains when touched and it is just too "bright". I know you can blue a gun. Have to strip the old finish down to bare metal, fine sand it, clean it good, then blue it -- but I am not sure if it can be done to aluminum. As I said the finish is very shiny, and if I sand it then the little lines would be visible when blued. Any info, directions or steps to take are appreciated ... thanks ahead.
Jane Skop
- Sterling Heights, Michigan, USA
March 15, 2012
Q. I have a .40 cal handgun and my boyfriend found residue inside. So we were soaking it in Hoppe's #9 ⇦ this on eBay or Amazon [affil links] for a day. Now the entire barrel (inside and out) is a dull black. It was originally shiny. We have been trying to wipe it clean buff it and all but nothing seems to work.
Any suggestions?
Jamie Cox
- Topeka, Kansas
October 15, 2012
A. Hi Janie,
Hoppes #9 is a brand rather than a product. They make cleaning solvents, lubricating oils, wipes, bore snakes. etc.
I believe that you can get it back to raw metal, but that you'll have to use a power buffer to polish the black coloration off rather than doing it by hand. Good luck.
October 15, 2012
Q. How do I polish a matte finish on my shotgun? I don't like the matte finish.
"Gunsmithing"
by Roy E. Dunlap
gunsmithing
or eBay or
chris hall
- White House, Tennessee, us
March 31, 2016
A. Hi Chris. A matte finish is a rough finish; and what is involved in getting to a polished finish is rubbing with an extremely fine abrasive until all roughness is gone and you have a very smooth finish. But here's the practical issue:
Just as you could theoretically dig a hole for the foundation for a skyscraper with a teaspoon but it would take centuries, to get from a very rough finish to a very fine finish with an extremely fine abrasive would also take forever. So what you actually have to do for practicality is to polish in 3 to 5 steps, with the first step using an abrasive that is coarse enough to remove the worst of the roughness in a short time; the second step is using an abrasive just coarse enough to remove the scratches that the first abrasive left in a practical amount of time; the third step just coarse enough to remove the scratches from the second, etc.
In this light, please review Kip's posting above. If you search this site for "polishing" you will find many more threads on the subject, with suggestions regarding what grit sandpaper to choose for each step, etc. Good luck.
A. Hi Chris.
Ted is quite right.
My solution is simpler:
Sell the gun and buy a shiny one.
Q. I have an S&W 357 mag model 19-3 that was bought in the 70s
It was originally blue, but a couple of years later my dad took it to a gun smith and had it turned to nickel or ss -- does anyone know what this process is called?
Jeff rice
- Hebron Kentucky
January 27, 2018
A. Hi. He apparently nickel plated it, Jamie. Or, as Geoff suggested, sold it and gave your father a shiny one :-)
I have an inherited shotgun with the occasional rust spot. I have already started using CLP and 400 grit sandpaper to remove some of the minor corrosion. Is there a problem with not re-blueing these areas? In other words, are these areas now more prone to further corrosion because they have lost the blue seal?
Steve
Steve Longh
- Charleston, South Carolina, USA
June 20, 2018
A. Hi Steve. The gun should, at the least, be cold-blued and waxed. Although the wax or oil provides most of the limited corrosion resistance, my understanding is that the bluing improves the oil-retention.
A. If your Gun is Stainless Steel or Chrome or Aluminium then use this ingredient and make solution you will get best shiny result like new surface ingredient as follow:
1. Phosphoric acid this on eBay or Amazon [affil links]
2. citric acid this on eBay or Amazon [affil links]
3. NP 9 (Nonylphenol Ethoxylate) ⇦ this on eBay or Amazon [affil links]
4. Butyle Glycol Ether ⇦ this on eBay or Amazon [affil links]
Waqas Naseer
Kansai Paint Pakistan - Lahore, Punjab, Pakistan
Oxynate No. 7
brownellsOxynate7
on Brownells
Q. Garage gunsmith .
I have learned to nickel plate using a hobby plating supplier's electroless kits. I also have gotten quite good at bluing with Brownells 0xynate7.
I would love to do the slide of a gun with bluing in the serrations and nickel on the slide.
Question is will nickel stick to the bluing or will bluing stick to the nickel ?
Want to make contrasting colors and finishes And wondering How to start without weeks of experiments.
MARC MCCONNELL
Garage gunsmith and restorer - Pearland, Texas
April 16, 2020
Nickel Blackener
nickel_blackener
A. Hi Marc. Nickel plating can only be done on clean, raw, active metal; you can't do it on top of bluing. However, you can blacken the nickel. Because the blackening is in the serrations, a relieved area, it will probably be reasonably durable like the blackening on the recessed areas of school rings even without hot bluing.
Q. What would blacken the nickel?
Could I nickel the slide, sand the high spots and then blue? Leaving the low spots like lettering and serrations nickeled? Think you see what I am trying to do.
MARC MCCONNELL [returning]
- Pearland, Texas USA
A. Hi Marc
Two points.
Electroless nickel can be difficult to control and is sensitive to such things as size of the part/volume of tank. It is also quite difficult to strip off if you get it wrong and need to start again.
Plating and especially the essential acid dips before plating can lead to hydrogen embrittlement so be prepared to bake your slide immediately after plating. A brittle slide is no one's friend.
birchwoodYouTubeBlackOxide
