Thread 214/31
OPC and Selenium Copier Drum coatings
Q. Dear Sir:
ACRONYMS:
OPC = Organic Photo Conductor
CGM = Charge Generation Layer
CTM = Charge Transport Layer
I am in need of something to coat OPC aluminum drums with the CGM, CTM; the thickness has to be uniform and ranging from 0.1 to 1 micron, any suggestions? Thank you for your time.
Mohamed Sinbel- Alexandria, Egypt
publicly reply to Mohamed Sinbel
Same question posted by:
MUHAMMAD IRFAN DIL- GUJRANWALA, Punjab, PAKISTAN
publicly reply to MUHAMMAD IRFAN DIL
Q. I want to start a small business of OPC drum recoating
yogee p deshconsumer electronics designer - nagpur, Maharashtra, India
publicly reply to yogee p desh
Need machine for OPC drum coating
Q. I am seeking information about machine/product available for coating/re-coating OPC drums.
Foram Shahprinter solutions - Plainsboro, New Jersey
publicly reply to Foram Shah
RFQ: Inquiring about machine / solution for copier drum coating. OPC primarily, but also Selenium drums.
Ken O [last name deleted for privacy by Editor]- Mexico City, Mexico
publicly reply to Ken O
RFQ: I am looking for a machine/product for coating/re-coating OPC drums.
Aivaras PyragiusPrintera Lithuania - Kaunas, Aukstaitija, Lithuania
publicly reply to Aivaras Pyragius
Q. Dear sir,
We are in copier field past ten years. At present we are very interested in manufacture of copier organic photoconductor drums coating. I want to know where I purchase the OPC drum coating technology. Is there any possibility for recoating the copier OPC drums? So you are requested to kindly give me some information about it.
R.Sujendrancopier machines servicing and trading - Chennai, Tamil Nadu, India
publicly reply to R.Sujendran
RFQ: Dear sir,
Please let me know selenium coating for the photo copier drum and which company provide us.
Best regards,
Rezaul Hoque
stationary - Dhaka, Bangladesh
publicly reply to Kazi Md.Rezaul Hoque
Q. I am always suffering from damaging the coat on the surface of the drum of copier machine. My question is how to regenerate the coating of this surface and which material is required for this purpose?
Saleh Matar-Zagazig, Egypt
publicly reply to Saleh Matar
A. If it is an inorganic coating, pure alcohol and a VERY soft cloth or pad; cotton is much too abrasive and will scratch the coating. Also ordinary rubbing alcohol has other stuff mixed in, so laboratory grade alcohol is essential. Another trick is make one copy with the cover open and nothing to copy. This should give an all-black copy. Then make two or three copies with the cover closed and nothing to copy. The first copy will have some dirty areas that usually clear up by the second or third copy.
For organic coatings, I've never tried. Maybe another reader here can help.
Tom Gallant- Long Beach, California, USA
publicly reply to Tom Gallant
Need opc drum testing, recoating and refurbishing portable machine for retail shop use for walk in customers
Francis W [last name deleted for privacy by Editor]toner refilling shop - Manila, Philippines
publicly reply to Francis W
Need drum tester and recoating and refurbishing machine. Chemicals needed to recoat opc drum.
Edmund Goink refilling - Bacolod City, Negros Occidental, Philippines
publicly reply to Edmund Go
Need OPC Drum Tester and Recoating and Refurbishing Portable Machine.
Arturas V [last name deleted for privacy by Editor]electronics mfgr - Lithuania
publicly reply to Arturas V
Hi. Our company need to buy OPC drum refurbishing machine. Can you help us to find this machine?
Kamran IsazadeProject Manager - Baku, Azerbaijan
June 1, 2009
publicly reply to Kamran Isazade
RFQ: Photocopier Drum and Fuser Coating machines needed. urgent requirement
akbar aurangwaleneeded in India - India
January 5, 2009
publicly reply to akbar aurangwale
RFQ: Dear Sirs,
We need to buy, and therefore find suppliers, for a OPC full renewing drum machine. By this we mean to make all the process, not only recoating, but renewing the whole OPC Drum.
We are a private company stablished in South Brazil.
We are looking forward to hearing from you soon and in advance we thank you for your cooperation.
Best Regards,
Refulling of Cartridge of all models - Blumenau, Santa Catarina, Brasil
publicly reply to Giovana Fiamoncini.
Q. HI,
I AM P.BHARATH FROM CHENNAI. I HAVE NEARLY 200 CUSTOMERS (HP PRINTERS). AND THEN I AM REFILLING FOR THEM. THOUGH I HAVE LOT OF OPC DRUMS WITH ME (USED). JUST I WANT TO KNOW IS THERE ANY POSSIBILITY TO RECOAT THE DRUM?
P.BHARATH- CHENNAI, TAMILNADU, INDIA
publicly reply to P.BHARATH
Q. I just want to know whether it is possible to recycle OPC drums, how to clean them, etc., to protect environment.
Nandyala Rama Satyanarayana Reddypaper - Guntur, A.P. India
publicly reply to Nandyala Rama Satyanarayana Reddy
Q. Is there is any technique for re-coating OPC printer drums?
Gurjot Pal SinghComputer Teacher - Jalandhar, Punjab, INDIA
publicly reply to Gurjot Pal Singh
A. Yes, Gurjot, there is. I have no experience in this, but I understand that it starts with a small lathe on which you mount the drum because the coating must be applied to a rotating drum, not by dipping. There are about a dozen companies that sell the lathes, recoating chemicals, and miscellaneous cleaners, swabs, and peripherals.
publicly reply to Ted Mooney
RFQ: I am looking for a company that can recoat large format photoconductor OPC drums, the drums are for the OCE 9400 large format printer, the drums are approx. 42" long x 4" dia.
Ken ReedDesigner - Clearfield, Utah, USA
publicly reply to Ken Reed
Q. Sir,
We want to make OPC Drums (like used in Laser Monochrome Printer), so what is the process of coating on aluminium drum, and which chemicals are used in OPC Drum Coating.
- India
September 13, 2013
publicly reply to Bhavesh Thesiya
RFQ: OPC Drum recoating Solution Needed
Sohaib ahmed- Gujrat, Pakistan
May 14, 2013
publicly reply to Sohaib ahmed
Q. I want to make OPC Drums (like used in Laser Monochrome Printer), so what is the process of coating on aluminium drum, and which chemicals are used in OPC Drum Coating.
ALI DAVOODISHARIF - IRAN,TEHRAN
May 11, 2019
publicly reply to ALI DAVOODI
A. Hi, readers. This site has 60,000 threads, and most of them work well -- if a topic/thread involves give-&-take, sharing, incremental improvements, specific troubleshooting steps, etc. it usually generates interesting and robust discussions!
But when people simply ask that whole technologies be transferred to them, it obviously doesn't seem to work very well. We've posted all the answers we've received on this topic, but as you see, there have been none in 15 years now :-(
If you want this thread to function well, like those other threads, try to be the change you'd like to see: please answer someone's question :-)
Thanks and Regards,
May 2019
