Cor-ten steel tube
I'm a steel sculptor working on outdoor pieces. I'm trying to get hold of some Cor-ten steel in tube form, as it forms a protective layer of rust and does not corrode completely, even after years of being outside. Does anyone know where I can get this from?
Rachel Merrington
- Cambridge, England
Ed. note: this forum is for technical postings and is made possible by supporting advertisers; they will respond in private to sourcing issues.
Cor-Ten was made by British Steel before they became known as Corus. Try a steel stockholder as a source.
What is the composition cor-ten a?
LLUMIQUINGA MARCO
- ECUADOR
Along with above satisfied answer I also want exact details for chemical composition of Cor 10 steel.
Please mail the details.
Amit Shelar
- Pune, India
April 17, 2009
April , 2009
Hi, Amit. Cor 10 is a proprietary, not a standards-based composition, so the only source for that info is the manufacturer.
