Electroplating on PP/ Plastics
Q. Can I do Plating on PP with EPDM content?
My current component is in PP, if I want to change to ABS for better plating the mountings will go haywire.
Is there any research done on doing plating on olefins/ PP?
Mayuresh Joshi- Mumbai, Maharashtra, India
A. Some olefins can be plated but the end product may not be very good. This can be achieved by either using a co-polymer or by special surface activation by plasma etching. Conventional chromic acid etching does not appear to be very good on olefinic monopolymers. The problem with PP is that it has a very low SG (less than 1 so it floats in water) and it has a high coefficient of thermal expansion. Combined with its reluctance to produce a chemically active surface, any metal coating has major adhesion problems, especially if the product is to be thermally cycled.
? I am no expert on plating-on-plastics, Trevor, and I do recognize that ABS is the predominant substrate. But am I wrong in believing that decorative plating-on-plastics started on polypropylene? I seem to recall programming large automated plating lines where they ran polypro parts through electroless copper and ABS parts through electroless nickel (or vice versa) after activation and sensitizing.
A. Ted,
I cannot answer your point about the origins of POP, as I was not aware of your point! My only comment is I have always found it very difficult to get a good adherent coating onto it. I would be very interested in knowing how the polypro was activated and sensitised in those days. Sorry I cannot shed any more light on your thoughts!
Thanks, Trevor. We'll have to wait for some oldtimer to either confirm this dim memory of mine or refute it. It was a very long time ago when I was only into the programming of plating machines and not the process chemistry, and my recollection was that the line handled both PP and ABS, and all work went through the conventional chromic-sulfuric etch and sensitization and activation first. It could be an erroneous memory though :-)
I want to know about electroplating on plastic process in detail.
Bo Bo [last name deleted for privacy by Editor]- Yangon,Yangon State, Myanmar
June 29, 2010
June 29, 2010
Hi, Bo Bo. Searching this site for "plating on plastic" will give you a number threads that discuss the general process sequence. But if you want the process in detail, there are books that detail it with all the particulars:
"Standards & Guidelines for Electroplated Plastic" is an outstanding one, but it is hard to locate copies.
I have not seen Plating on Plastics: A Practical Handbook ⇦[this on Amazon affil links], but have reason to believe that it is very good. Good luck.
Q. I am an engineering student. I would like to do the project of electroplating for my academics but is it affordable for me?
Please give details if possible.
student - Mumbai, Maharashtra, India
January 16, 2013
A. Hi Sameer. Automotive quality plating on plastic, which requires outstanding adhesion, would probably be beyond your budget and convenient resources.
But a more generalized plating on plastic or organic materials sounds quite doable. Please see our FAQ, "Plating Organic Materials". Good luck.
January 16, 2013
Q. Hi, Is there are some news about electroplating of polypropylene (PP)?
Kacper Beblocinski- Czestochowa, Silesia, Poland
May 20, 2018
A. Hi Kacper. You can try 'plating polypropylene' at surfacequery.com and see if anything comes up. Most of the papers published in finishing journals are indexed there. Good luck.
May 2018
