Copper sealer for counter tops
Q. Following up on question 8137, posted by Jim G. of Wichita Falls, is there a good, non-toxic sealer for copper countertops?
Sarah R [last name deleted for privacy by Editor]
- Dallas, Texas
similarly
I also would like to know about a copper counter sealer. We have 5 counters with copper sheeting on them that look just great, but upkeep can be a problem. We would like to seal them if possible. Is it possible once they are in place?
Tara B [last name deleted for privacy by Editor]
- Brighton, Michigan
Same problem - we have a copper table top that being destroyed by everything that touches it... any info is helpful...
Chris K [last name deleted for privacy by Editor]
- Albuquerque, New Mexico
Brass Lacquers
brass_lacquer
A. Hi, folks. The banner at the bottom of the page will direct you to some specialist lacquer and clearcoat suppliers. See letter 22765 for a coating suggestion, as well; but see letter 13168 also, which suggests leaving your copper uncoated. Good luck.
Q. I am trying to locate someone to do copper countertops and backsplash and can't find anyone. Can you tell me who installed yours?
Dana D [last name deleted for privacy by Editor]
- Highland Village, Texas
Q. For those who have gone before me - copper countertop in Kitchen - pros and cons?
I have had to fire a contractor and I am subbing the job myself. The 3-5 month job has turned into a 14 month ordeal! I desperately need some advice before making one of my last decisions. For those having a copper countertop, I would like to know the pluses and pitfalls of having the copper. From a professional fabricator, I ask about a recommended thickness of copper for durability; methods for achieving a mid-toned antique looking color; type of wax, method of application to seal and maintenance; type of construction and material recommended for under the copper; method to attach under counter mounted sink -- and any recommended fabricator in the Dallas, Texas area?
Any and all information would be greatly appreciated!
Susan C [last name deleted for privacy by Editor]
consumer - Dallas, Texas
A. Copper counter tops in the kitchen or bath are extremely beautiful but do have some ugly sides. Sealing a top for every day use is very difficult, it still requires anal upkeep and habits of use. I've made a lot of table surfaces and work surfaces and in most cases I want my customers to be 100% natural. I do use natural patina solutions and waxes when possible, but this is not always the best way. I have used an inhibitor lacquer system for tops that receive a lot of use, but even this will break down over time. I have several tops out that I applied a resin based finish over with excellent results, but beware when using acid base patinas. I just recently finished copper tops applying a catalyst type lacquer finish over a acid based patina but too soon to tell how well it will hold up. I recommend anyone considering copper tops that you either be willing to maintain the copper or just learn to accept the natural ways of the copper. I choose to use 16 oz or better especially if welding is involved and the use of 3/4 or better underlayment for support like mdf sheet.I do glue my lite sheet fabrications down, do not use silicon. I hope that I answered some questions.
Bernard Shelton
- Clarkedale, Arizona
September 2, 2008
A. Dana
You can try some local sheet metal shops in your area for help doing copper countertop. It is hit and miss but I have found some of the older shops are able to do them, just depends on your area.
Don Angelo
Spring Hill, Tennessee
April 21, 2010
A. My husband is a roofing contractor who does standing seam metal panels, copper gutters, downspouts and the like. He recently made copper countertops for a friend, and they look great. Maybe you could try a roofer or ask a local building supply company in your area for a referral.
Michelle Dumsha
- Pasadena, Maryland
August 17, 2017
