Looking for sealant protection for copper counters
We recently built a new home and I had a local person fabricate copper counters for me, which I absolutely love. However, the constant upkeep is causing me to reconsider the decision. Is there a sealant or finish that I can use to eliminate the need for constant polishing?
Gretchen Harrington
- Newbury, Ohio
Incralac this on eBay or Amazon [affil links] will do the job. Good Luck
Donald Chapman
- Strasburg, Ohio
Gretchen,
A high quality lacquer will do the job. Minwax makes a good brushable lacquer that does not leave brush strokes. You should be able to find that in any home improvement center. Make sure you purchase a good brush to use.
Don
Don Angelo
Spring Hill, Tennessee
nikolasbanner
"Clearcoats/Lacquers for Brass from G.J. Nikolas"
