What are pennies made of?
penny
U.S. Mint Image
Q. What is a penny made of? How do they make pennies now days?
JIMIE P [last name of minor deleted for privacy by Editor]
- Chamblee, Georgia
A. Hi, Jimie. Pennies today are made of zinc blanks (circles of zinc are punched out of sheets of zinc, like cookies are cut out of a sheet of dough with a cookie cutter). The zinc blanks are then electroplated with copper in plating barrels (we have an article with pictures on line about barrel plating), so the core of the penny is zinc but the skin is copper.
After the copper plating, they are stamped with the familiar head of Lincoln and the date, etc. Coins such as pennies have a raised rim (the lip around the penny is thicker than the body of the penny); this is created by rolling the coin through a passage that is slightly smaller than the original size of the blank so the extra material must mush up as this fatter edge.
Good luck with your project.
Q. Hi guys I really need to know how are pennies are made because I'm looking up how are coins made and if you can tell me what all the coins made that will be AWESOME!
Shalonda S [last name of minor deleted for privacy by Editor]
- Ferndal, Michigan
A. C'mon, cousin Shalonda, we just finished telling you how pennies are made :-)
But besides the info already given, you can find more about coins at the US Mint site, www.usmint.gov. Also, the History Channel has a nice several minute film clip on how coins are made, although we don't know how long it will remain on line. Good luck!
Q. When did pennies go from solid copper to zinc clad?
Herb S [last name of minor deleted for privacy by Editor]
- Munroe Falls, Ohio
"Pennies"
pennies_book
AbeBooks
A. Hello, Herb; it was 1982. Some 1982 pennies are zinc cores plated with copper, some are solid copper. You can weigh a 1982 penny to see which kind it is. You can search the site for many other factoids about pennies. Good luck.
Q. I was told (an old wives tale, perhaps) that if a person is stung by a bee, the copper in a penny will help calm the sting. Given this is true, would the pennies made after 1982 still be able to accomplish this home remedy?
Megan B [last name of minor deleted for privacy by Editor]
- Houston, Texas
A. Hello, Megan. If we assume that the copper on the surface somehow reacts with the fluids in the sting area to soothe it, the fact that the core of the penny is zinc might be irrelevant.
But you raise an interesting point with "given this is true, what then?" :-)
That blows the needle right off the subjunctivity meter: "If an antelope is a terrifying carnivore, is it because an antelope is a lion or because it's a tiger?"   :-)
Quite a question.
Q. Homework: what metal were the pennies made from in the past?
kareli [last name of minor deleted for privacy by Editor]
student - elgin, Illinois
A. Don't just post your homework question, cousin Kareli -- teachers tell us to just tell the students to "Do your own homework!" But if you tell us what you are having difficulty with, we might be able to help you over the rough spots. Before 1982 pennies were made of solid copper, all except in 1943 when pennies were made of steel plated with zinc because copper was in short supply due to WWII.
A. The U.S. penny since 1982 is made of 99.2 zinc and 0.8 copper, with the outside plated with copper.
Ann-Marie C [last name of minor deleted for privacy by Editor]
- Saint John, NB, Canada
July 6, 2008
Q. Hello my name is Annika I am researching the past of US Mint and I am interested in pennies, my question is why does Abe Lincoln face right when all the other portraits face left?
Annika S [last name of minor deleted for privacy by Editor]
student - Numine, Pennsylvania
September 25, 2008
A. Hi, Annika. There is no particular reason, conspiracy theories aside :-)
It just happens that the portrait and bust of Lincoln that were used as the model face that way. Also some Jefferson nickels face left and some face right.
October 12, 2008
Q. My name is Mason and I'm in the 6th grade, why do they use zinc and copper, why not just one?
Mason R [last name of minor deleted for privacy by Editor]
student - Oklahoma
December 27, 2009
A. The reason pennies use zinc now and not just copper is that it's cheaper. Copper has become expensive. Because zinc is cheaper, most of the penny is zinc, but the outside is copper so it looks the same (I guess). It still costs more than one cent to make a penny though. :)
Jordan Christiansen
- Rosemount Minnesota
Q. Since the cost of copper has increased so much recently, I'd like to know what is the value of a full copper penny?
Drexel J [last name of minor deleted for privacy by Editor]
student - Jacksonville
August 2, 2010
A. Hi, Drexel.
As a student, one of your most important jobs is to learn how to "put 2 and 2 together" to solve problems, rather than asking someone else to do so and just give you the answer :-)
To solve this problem you have to find out how much a penny weighs, and then multiply that by the current value of copper per unit weight. If you don't have a scale, you can search this site for "How much does a penny weigh?", you'll see the answer is about 3.1 grams. Then you can google "copper london metal exchange" for the current price of copper to get your answer. Good luck!
Q. I am sorry to ask this question out of the blue but I want to cite this page. When was this page electronically published?
Paul n [last name deleted for privacy by Editor]
- Bradenton Florida USA
September 21, 2011
A. Hi, Paul.
Mark Twain once said that New York will be a beautiful city if they ever finish it. NYC and forum pages like this are "works in progress", so the idea of "publication date" doesn't really apply. The first entry on this page was from 2001, and the most recent entry before yours was Sept. 23, 2010. The usual way to cite a webpage is to include the URL (web address) and say "retrieved Sept. 22, 2011". Then you print out the page or save it in a ".pdf" or other format whereby you have a copy of how it looked the day you cited it. Good luck.
Q. I am a middle school student wondering how exactly you make pennies? How much do pennies weigh? Are they still made of copper?, and how much? What are all the ingredients in a penny?
Cheyenne F [last name deleted for privacy by Editor]
Student - Newville, Pennsylannia USA
October 3, 2011
A. Hi, Cheyenne.
School and study are not about simply asking someone else to do your homework or science project for you :-)
I believe that every one of your questions is already answered without even leaving this single page. If you have questions that are not answered on this page, please try to phrase them in terms of the answers already given, like: "I see that pennies are made by punching blanks out of a sheet of zinc, like using a cookie cutter on dough, then copper plating them, then stamping the images onto them, then rolling the edge, but what I don't understand is . . ." Good luck.
Q. Are you the author of this page? Is finishing.com the company?
Cheyenne F [returning]
Student - Newville, Pennsylvania USA
October 6, 2011
A. Hi, again, Cheyenne.
I didn't author the words you just wrote, so it would probably be better to call me the editor of the page than it's author. But I am the author of whatever I've personally written here. Yes, Finishing.com would be the publisher.
If you wanted to put in your report that "Pennies are made of round blanks of zinc that are then copper electroplated", and you wanted to cite this page as the source, you could say: 'Mooney, Ted, "What are pennies made of?", Finishing.com Inc., Pine Beach, NJ, USA, retrieved 10/6/2011 from www.finishing.com/111/59.shtml'. You can google "How to cite a website" for various standardized citation formats. Good luck.
October 6, 2011
Q. Is abelsonite in pennies? :)
Secelia P [last name deleted for privacy by Editor]
student - Toledo Ohio USA
October 30, 2011
wikipedia
Abelsonite
A. Uh, no, Secelia.
Of the billion and one things that are not in pennies, Abelsonite is one of them :-)
Which begs the question, why do you ask?
! I really like this website. For my experiment for my Science Methods I decided to do pennies and lemon juice to see if the copper would come off and make the pennies shiny. It has so far worked which is really cool! Thanks for posting about the pennies from 1982 and before. Some of the pennies from the upper 1980's still work with this experiment. I didn't even have to ask a question it was already answered; so thank you. Cindy
Cindy U [last name deleted for privacy by Editor]
- Lamoni, Iowa, United States
December 5, 2011
Q. I am wondering why copper became expensive after 1982? Why is zinc cheaper?
Kyra M
curiosity - Wild Rose, Wisconsin, U.S.A.
March 15, 2012
A. Hi, Kyra. Copper didn't suddenly get expensive in 1982. Rather, the government causes inflation by printing more money, whereby the relative value of money gradually but continually declines, so most things get gradually more expensive over time, and 1982 was just the point at which the US government decided something had to be done about the fact that the cost of the amount of copper needed for a penny now exceeded one cent. This would be a problem because people (and foreign governments) could buy up pennies and then melt them down and sell the copper.
Zinc is cheaper than copper because because there is more of it, or it is less in demand, or it is easier to produce (a subject for another project).
March 16, 2012
Q. Should America get rid of the penny?
Peter Tilly
- Roswell, Georgia, USA
May 7, 2012
A. Hi, Peter. If we get rid of pennies, the states will round up sales tax to the nearest nickel, as well as escheating the extra cents, which will cause more inflation and reduce the value of nickels.
But seriously, while it's valid to post certain questions, posting a homework assignment and expecting someone else to write the essay for you would be a bit over the line :-)
I am writing a speech on the coin value. Especially since the word out is that the penny and nickel cost more to make than the value of the coins itself. I'm trying to compare how copper, zinc, and nickel are valuable so I can fit it into my speech. I have been looking for websites and I even checked the Mint website, but nothing seems to be the right answer I'm looking for. Will you be able to help me out with this one? Can you tell me how valuable copper is? Also how valuable or less valuable zinc and nickel are? Thank you so much for your time!
Volena T [last name deleted for privacy by Editor]
- Stockton, California, United States
May 9, 2012
A. Hi Volena.
Google the metal in question combined with "London Metal Exchange". Good luck.
May 2012
Q. Why are pennies from one year MAGNETIC?
Alyssa [last name deleted for privacy by Editor]
- Massapeaqua Park, New York, USA
April 4, 2013
A. Hi Alyssa. Because they were made of steel, and steel is magnetic. Good luck.
