  Thread 11/52
Touching up powdercoating
I've a black glossy powder coated enclosures (stainless steel). And quite often I've some spot on it. From the supplier it comes from small particle covered by powder and then baked. They can't detect it before baking. I asking myself if some rework can be done as those spots are small (diameter between 0.3-0.5mm) (actually my supplier have to redo the whole process ... time consuming).
Here are some picture related to my problem.
First picture shows spot under microscope, second picture is the same but with a 0.3mm diameter circle as reference.
Any help to understand the origin of the problem (if different from what stated before) and the most important: an idea to rework this spot.
Sincerely
Jojo lib
- Paris france
July 7, 2021
publicly reply to Jojo lib
Ed. note: We have no photos from you jojo. Please email them to mooney@finishing.com for posting here.
A. Need the images to see what this is, but there are various touch up systems involving aerosol alkyd paints available and widely used.
geoff_crowley
Geoff Crowley, galvanizing consultant
Crithwood Ltd.
Bathgate, Scotland, UK
crithwood logo
August 10, 2021
publicly reply to Geoff Crowley
Q. Presently we use a waterbase paint for touching up our powdercoated parts with scratches. This paint isn't very durable against some commercial cleaning agents used on our product. Is there a more durable paint which could be brushed on and easily color-matched in small quantities? We are using a polyester semi-gloss powder with a small orange peel texture. Thanks for any advice you can give.
Brian M.
publicly reply to Brian M.
Ed. note: Generic types of paint only, please, gentle readers -- not brands or sources! (why?)
"Powder Coating Complete"
by Nicolas Liberto
Q. Our interest is in touch-up effective for exterior installations. Thanks,
Joseph Drury
publicly reply to Joseph Drury
Q. Which is the best way to do small reworks / touch ups in powder painted jobs. We do not want to use "touch up" sprays / "aerosol" containers.
Nanda Srikakulam
Otis elevators - Bangalore, India
publicly reply to Nanda Srikakulam
A. Dear Sir,
Use repair kits that exist of a liquid 2-Component paint. Ask your powder supplier for these repair-kits.
Hope to have been of help.
Remmelt Bosklopper
Remmelt Bosklopper
- Enschede, The Netherlands
publicly reply to Remmelt Bosklopper
Q. Hi I need to know if I can mix the powder with anything to create a touch up?
Nols Britz
hobbyist - Amanzimtoti, South Africa
September 8, 2010
publicly reply to Nols Britz
"a Practical Guide to Equipment, Processes and Productivity at a Profit"
A. I have been experimenting with mixing the powder with paint thinner and then brushing it on, baking it and then sanding off the excess. If you have any other ideas please let me know. The parts I am powder coating are for outside use and paint does not hold up as well.
Ed Howells
publicly reply to Ed Howells
A. We have had some success mixing a little bit of the powder we use in some acetone this on eBay or Amazon [affil links] Warning! highly Flammable! or M.E.K. This is good only for color though and will not reproduce texture. This mixture can be brushed or sprayed on.
Budd Black
metal finishing - St. George, Utah
publicly reply to Budd Black
A. We have found mixing powder with paint thinners to be suitable for us, although this method will not work with metallic colors. We are using polyester powder.
daniel coyne
powder coaters - wodonga victoria australia
publicly reply to daniel coyne
Q. We recently changed our painting process from solvent based Lacquer to both Waterborne Acrylic and Epoxy powder (about 50% each).
We send out aerosols as touch-up for minor defects of scratches during installation. The aerosols are solvent based lacquer formulations. Our customers are having problems with adhesion when applying the lacquer over the acrylic waterborne or epoxy coatings.
My feeling is that they not only use it as touch-up but also to change the entire color that is causing the problem. Is there one aerosol that will work on both the waterborne acrylic and epoxy coating? Would a primer help? What about surface prep on a job site as this is very important to adhesion?
Billy R. Hudson
- Monroe, North Carolina
publicly reply to Billy R. Hudson
Repairing powder coat on Harley aluminum head and chopper frame
Q. HELP. I RECENTLY SCRATCHED THE POWDER COATING ON THE ALUMINUM HEAD OF MY 'NEW' HARLEY-DAVIDSON. I'VE TRIED USING A PASTED ALUMINUM CLEANER WITHOUT SUCCESS. COULD YOU PLEASE RECOMMEND A REMEDY?
SINCERELY,
JEFF HOWARD
TROUTMAN, North Carolina
publicly reply to JEFF HOWARD
A. The best way to repair damaged powder coating on either a head or other powder coated components on any motorcycle is to remove the affected part and have the powder professionally removed and re-powdered. This can be done by several job shops in the United States. There are a few that can remove powder from aluminum parts and most can remove powder from steel parts without affecting the surface of the part.
Ken White
publicly reply to Ken White
Q. I recently scraped the bottom frame rails of my custom chopper, as I was attempting to load the low-slung motorcycle into my trailer. I know the frame is powdercoated, and totally disassembling the bike to re-powdercoat the frame is not feasible. How can I eliminate the scrapes without re-powdercoating?
James Rees
hobbyist - Jonesboro, Arkansas, USA
publicly reply to James Rees
A. Maybe no problem James. Most powder coating can be touched up with regular paint. It would surprise me if the manufacturer does not offer those little bottles of touchup paint. But if they don't, take it to a consumer-friendly powder coating shop; they will know what to do. Good luck.
publicly reply to Ted Mooney
Q. Hi, I drive a late model race car and we have a powder coated frame. We want to enter the car in an upcoming mall show but the frame has some flaws with the coating. I just wanted to know if there is a way to touch up the powder coating without having to strip the car completely. Thanks.
Eric Kauffman
hobbyist - Reading, Pennsylvania, United States
February 9, 2008
publicly reply to Eric Kauffman
A. Sure, Eric, most powder coating is easily touched up with liquid paint. There is not necessarily any compatibility issue. This repair may not be perfect, as earlier responders have noted, but it will improve the looks and the corrosion resistance of the scratched area. Good luck.
February 12, 2008
Method for Touching Up Powder Coating
Q. Dear Sir,
We receive powder coated parts which sometimes get scratches in assembly line. Can we patch up before final packing. If we use a pressurized paint canister to spray on effected area then is any pre cleaning needed?
Ratanjit Singh Sohal
India
publicly reply to Ratanjit Singh Sohal
Q. Our customers require us to assemble Powder Coated parts. Sometimes they are pitted or damaged. Is there a way to touch-up Powder Coating or Handling defects?
A. Korselman
- San Francisco, California
publicly reply to A. Korselman
A. Dear Mr A Korlselman,
This query has been answered by me on an earlier letter but at the risk of repeating myself here goes:
Dissolve the same powder used in the coating in TC or any NC based thinner in which the powder dissolves. Touch up the scratched area with the resultant Paint /paste/liquid powder whatever you call it with a suitable paint brush.
Experience will give you an idea of how much your Solvent/ powder mix should be.
All the best,
Regards, K Vahanwala
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
publicly reply to Khozem Vahaanwala
Thermoplastic touch up for powder coating with a glue gun
Q. We currently powder coat wire rack for the refrigeration industry. the material is applied using fluid bed. The problem we are having is touching up the hook marks from the dipping process. Do you type/method of liquid touch-up that can fill these marks that are approx. 4 mils deep and 1/8" wide.
brian money
- cleveland, Ohio
publicly reply to brian money
A. I have seen a very good method of touching up hook marks like you describe. There is a manufacturer close to us who makes a thermoplastic patch stick which fits into a typical hot-glue gun. You simply melt it onto the mark like you are glueing parts together. Maybe someone close to you makes this type of product. It is much faster than waiting for a liquid touch-up to dry.
Paul Norman
Paul Norman
- Odessa, Texas
publicly reply to Paul Norman
Touching up powder coating causes over-curing
Q. Are powder coating touch-up systems commercially available? A current system for touch-ups doesn't have appealing aesthetic quality? After applying the powder to the affected area, the powder is cured, and the powder coating in the surrounding area is over-cured? Does anyone have any suggestions?
Caleb Hammons
- Warner Robins, Georgia, USA
publicly reply to Caleb Hammons
A. Hi,
Most powder coaters use aerosol car spray paint or a small pot of car paint and brush.
Terry Hickling
Birmingham, United Kingdom
publicly reply to Terry Hickling
A. Caleb, it sounds like you are saying that you try to touch up powder coating flaws by re-applying powder to the flawed area and then re-curing it causing the first coat to over-cure and change color. The proper way to fix a powder paint reject is to sand (or chemically strip) the whole part, not just the bad area, and then repaint it.
There are aerosol suppliers that will match the powder you are using so that you can do touch-ups.
Some powder suppliers match their own powders in aerosol, so you might want to ask your rep if they provide that service, or maybe he can recommend someone to you.
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
publicly reply to Sheldon Taylor
Q. How we can touch up the scratched areas on powder coated surface using epoxy ester powder / pure polyester powder? Is it advisable to spray paint to cover up the scratched areas on powder coated surfaces or what would be the solution?
M.SIVAKUMAR
- Chennai, Tamil Nadu, INDIA
publicly reply to M.SIVAKUMAR
A. Spot touch up is the best solution for very small areas. For larger areas, it is best to touch up with a Pu based automotive paint (gives good performance over these areas).
Amit Amembal
- Mumbai, India
publicly reply to Amit Amembal
Q. Mr. Amit,
Sorry for responding to you belatedly since I was out of station. First I thank you for sparing your valuable time and answering my question. Kindly tell me what paint I should use for spot touch up? Also tell me whether PU spray painted parts instead of powder coating would give the same results in all terms? Have a good day! Thank you once again.
M.SIVAKUMAR
A. Hi Sivakumar. We merged your inquiry into a thread which offers lots of perspectives on the situation. However, no, a touchup will never be as durable as the original powder coating (consider that the scratch may have also scribed through the pretreatment). If you need perfection, you need to strip the powder coating and start over. Sorry.
Need a repair spray with texture
RFQ: I am looking for an aerosol spray that can spray out grey rough texture colour to do touch up work on texture type powder coating.
Ramoo Puru
Singapore
publicly reply to Ramoo Puru
RFQ: I need touch up paints for Rohm & Haas powder coat colors Textra Black Sand and Textra Chestnut.
Diane S [last name deleted for privacy by Editor]
Steel Sculptures - ST. LOUIS, Missouri, USA
publicly reply to Diane S
Ed. note: Current, active RFQs are now on our "Looking for Products & Services for Our Finishing Shop" page.
Want cleaning solution to remove hit marks on powder coated workstation legs
Q. We have an issue of hitting or dragging marks on office workstation legs (powder coating removes off slightly). Since its very costly to replace the legs, can anyone suggest how these marks can be removed WITHOUT affecting the powder coating
Venkat Balakrishnan
Quality Engg - Chennai, India
November 11, 2014
publicly reply to Venkat Balakrishnan
A. Hi Venkat. Waxing/polishing sounds like the easiest approach for faintest marks. For deeper marks, the rubbing compound this on eBay or Amazon [affil links] and scratch removers sold in auto stores should do it. Where the powder coating is deeply scored or missing, then touching up as described by Khozem and others above should work.
November 2014
Best way to re-coat a part without affecting the color?
Q. I basically have a run of parts that have been powder coated but due to the nature of the bends in the sheet metal and the way some of them were placed on the conveyor the powder did not catch on on the insides of some of these parts (inside of the bend which is not visible). Was just wondering what the best way to touch up the paint would be, manually using a brush would be pretty labor intensive and slow and sending it through to re-coat the entire part might darken the color which I cannot have. Would it be possible to just spray the inside of the bend where it didn't catch on and then cure it again?
Varun A.
- Dubai, UAE
December 9, 2014
publicly reply to Varun A.
A. Hi Varun. We appended your inquiry to an earlier thread with some helpful ideas. Remmelt Bosklopper's idea of spraying a 2-part coating (such as an automotive clearcoat) on the poorly coated and non-visible area sounded good to me :-)
December 2014
A. Partial re-spray with powder usually adds to the problem. The partial overspray onto already coated parts causes a grittiness in the coating loosing gloss. If using powder, then full respray. Don't forget adhesion. What will be the adhesion mechanism of your new top coat to the original coating? Better to sand it to get a key between coats.
Alternatively, used a matched colour liquid paint as touchup from an aerosol.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
December 12, 2014
Green Powder Coating Tape
tape_powder_coating
I hear a lot of answers saying to sand before applying a second coat or color change.
From experience I'd like to add some helpful tidbits of information for anyone seeking an answer to recoating a piece that's already been coated.
If you have a media blaster / sand or other and you have experience with it, you can save a lot of time and effort by preparing the surface by hitting it with a media that won't take the powder coat off it, simply prepares it for another coat.
One of the most important things to remember when recoating is the piece might be difficult to get a connection to complete the statically charged surface. What I do when I'm in doubt is to preheat the piece at about 250 °F.
It can be tricky to manage but if you are properly set up, you will be able to do this with ease. use a low bar settings on your gun and dust it with a generous coating of the color you've selected. Put it back in the oven and bring it up to temp for 5 minutes, then shut the oven off and let everything cool untouched.
The surface coating will be very well adhered to the substrate powder coat. You can use this same method for multicolor applications, using masking tape. If you are familiar with pinstriping tape, that is the type of accuracy and delicacy it takes to work with a warm to hot precoated part. No fingers can touch the surface. have your tape prepared and your piece stable enough to work on. I have multiple fixtures from wire hangers to grates to magnets that I use to stabilize, hang or secure to work on. You might find that an assortment of magnets very handy. They can hold a hot piece through a precoat and take a fair amount of heat.
You can make electromagnets very easily that works off a switch and is unaffected by the temps normally required for general powder coating.
With a little practice and patience you will find that magnets will help the powder to adhere using them to enhance the electrostatic. Those are my helpful tidbits of intell.
I am self taught and I build hot rods. I have powdercoated parts that others said would stand up to the test of time, wear and tear, and I, as they are amazed. Through some simple enhancements you can make a bond that is virtually impenetrable through heat cycles knocks and bangs from wrenches etc, holding up amazingly well.
Practice on awkward shapes, multicolor, masking and plugging areas to keep uncoated, or to keep a base color. Have fun with it. Stop at the dollar store and buy things in the kitchen utensil department that will challenge you. Nothing ventured nothing gained.
Steve Lindsay
heritage Hot Rod - Oxford Station, Ontario, Canada
publicly reply to Steve Lindsay
Can I powder coat an uncoated area (masked off during first coat) of a powder coated cylinder?
April 14, 2016
I have an 9" diameter aluminium tube. It was powder coated successfully but I asked the engineer to mask off a strip 1" wide towards one end of the tube (the strip goes around half of the circumference of the tube, not along it).
The problem is that the engineer misunderstood my instructions and the mask goes along the bottom half of the circumference instead of the top (I can't just rotate it as there are components that are welded on that need to be at the top). Also the strip is not completely straight either and does not look great so I'm thinking scrap the masked strip idea altogether and just get him to powder coat the masked area.
1152
My question is: is this possible? Can you powder coat aluminium a second time? will the masked area then become indistinguishable from the rest of the housing? Any advice appreciated! The coating is: Harley Davidson Engine Black Texture:.
James
James Hopkins
- London, UK
publicly reply to James Hopkins
A. Hi James. I think Khozem's posting is the most applicable response to your situation, but "indistinguishable" is an awfully tall order, the more so for a texture paint :-)
Luck and Regards,
April 2016
A. The answer is No.
If you re-coat, you will overbake the initial coat leading to brittleness and loss of properties.
Best to strip back to bare metal either chemically or mechanically and re-process with more care.
Hope this helps.
Bill
William Doherty
Trainer - Salamander Bay, Australia
April 20, 2016
publicly reply to William Doherty
Q. What is a protective coating that can be applied to a matte powder coat metal sign to help prevent scratches? A spray would be easiest for application purposes but we are open to suggestions.
The sign is already installed so sending it back to the powder coating company is not an option. Custom's belts and purses scratch the metal when they lean against the front desk.
Mackenzie Privette
- Gainesville Florida USA
June 20, 2017
publicly reply to Mackenzie Privette
2K Clearcoat
clearcoat_2k_spray
A. Hi Mackenzie. Metal is harder than organic coatings like powder coating or clearcoats, so the problem is not 100% solvable. But the hardest coating you will be able to conveniently apply on top of that powder coating is probably a two-component automotive clearcoat (the chemical reaction makes for a harder cure than you would get from evaporation of wet paint or clearcoat, and I think you want to avoid baking or UV exposure).
I haven't tried it, but there is a two-component clearcoat in spray cans that should be worth trying if you can't get an automotive painter in there to mix and spray with professional equipment. Good luck.
June 2017
Please suggest how to rework oil mark on powder coated parts.
GANESH P. SONONE
coatings - aurangabad India
January 13, 2018
publicly reply to GANESH P. SONONE
? Hi Ganesh. Hopefully another reader will prove more insightful than me, but I don't think I would even know how to try to offer any help without you more clearly describing the defect and some background facts, and seeing pictures of the oil mark (e-mailed to mooney@finishing.com). Sorry, but I simply have no suggestions except stripping the powder, re-cleaning the part, pretreating it, and powder coating it again. Good luck.
January 2018
