Paint Analysis
What test can be done to tell whether a cured coating is paint or not from a coated part?
Binh Nguyen
- Peoria, Illinois, USA
Binh,
Infared analysis could be used to compare the cured coating to a know standard of the coating. The resins or polymers in a coating tend to have characteric Infared spectrums. It may be difficult to tell two coatings apart made by different manufactures with the same type of resin, but this technique can tell the difference between coating made with different resins and non coating materials.
Roy Nuss
Trevose, Pennsylvania, USA
