Need electroformed copies of Fresnel lens
1996
RFQ: I am looking for a shop that can produce electroformed copies of a fresnel lens. The lenses have a 25 mm radius and the grooves are 0.2 mm deep.
Fernando E [surname deleted for privacy by Editor]
Q. Fresnel Lens is a new subject to me. I also need some help on this topic.
GUOLIN P [surname deleted for privacy by Editor]
UAH - Huntsville, Alabama
1997
A. Hi Guolin. Berl Stein is the guy I'd contact if I were you. He was recently employed by Fresnel Optics / Reflexite Technology, and is now president of NiCoForm [a finishing.com supporting advertiser].
(This entry re-checked and still valid, November 2012)
A. Fernando, Goulin and anyone else needing a quote on a Fresnel lens. Call Donna at Fresnel Optics [Rochester, NY] to get a quote.
Cheers from PlaterB
berl stein berl sig
"PlaterB" Berl Stein
NiCoForm, Inc.
Rochester, New York
nicoform
1997
"Solar Energy projects for the Evil Genius"
RFQ: Dear Sirs,
For a job we are going to produce, we need 1000 fresnel lens 25.5 x 18 cm.(about).
We do not need particular enlargement.
If someone could help me giving directions, thank you in advance,
Luca B [surname deleted for privacy by Editor]
- Fusina, Italy
1997
A. I run an electroforming facility which can create the electroforms for the fresnel optics. We duplicate very precise holographic microstructures with nickel process. These can be either hard or soft and thickness tolerances are within microns.
Tim Dolan
Bridgeport, Connecticut
1997
