DEFRIC - FTB 116 / HMB-2 Solid Film Lubricants
Q. Can you give me any information about a process called DEFRIC - FTB 116 Thanks!
Mr Richard Smith1996
1998 Q. Searching for information about a process called "DEFRIC". Possibly of Japanese origin. A nitriding process? ![]() ![]() Tom Pullizzi Falls Township, Pennsylvania |
A. Defric coating is a solid film lubricant which can provide resistance to corrosion and facilitate lubrication in extreme conditions. There are 300 kinds of Defric coats. Main Defric coat products either Molybdenum disulfide or Graphite or Fluorine based Lubricants.
Regarding mode of application … well common method is through Spraying on work piece and then drying in the oven at temperature of about 180 - 250 °C.
Automotive/Manufacturing - Lahore, Pakistan
Q. We are planning to apply Defric coat HMB-2 to bore of our motorcycle gears.
Since this shall be new coating to us, we would like to know process of applying this coating to bore of gear.
Maker of this coating is requested to quote for process and chemical.
We are a trading company in Indonesia specially dealing with maintenance chemicals including coatings or paints. maintenance chemicals - Jakarta, DKI, Indonesia 2007 Ed. note: This RFQ is outdated, but technical replies are welcome, and readers are encouraged to post their own RFQs. But no public commercial suggestions please ( huh? why?). March 10, 2011 Q. I am looking for additional information regarding Defric coatings. The gentleman in the thread previously stated that there are 300 some odd Defric coatings. My question is, where might I search for this information. Is there a particular company that deals in these. Ed. note: This RFQ is outdated, but technical replies are welcome, and readers are encouraged to post their own RFQs. But no public commercial suggestions please ( huh? why?).
This site's supporting advertisers cheerfully make the site available for technical discussions and camaraderie, but they would justifiably have a problem if the readers, instead of contacting them about their dry film lubricants and coating needs, ask them to bear the cost of posting detailed distributorship info for their competitors who don't support the site :-) Regards, ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey March 11, 2011 A. The coating thickness allowance must be calculated and incorporated in the drawing of the component on which the coating has to be applied. Aamer IkramEnergy Sector - Calgary, AB, Canada May 17, 2011 Molybdenum disulfide vs. manganese phosphate coatingsQ. What is the difference between manganese phosphate coating and Defric coating? Is manganese coating recommended for pistons of HFO [heavy fuel oil] engines? AHMAD RIZWAN- lahore, Punjab, Pakistan June 3, 2014 A. Hi Ahmad. Defric is only a trade name and does not specify the technology of the coating. But we assume that you are referring to molybdenum disulfide coatings? These are "dry film lubricants" rather similar to graphite in function. Yes, manganese phosphate coatings are used on piston rings and other lubricated machine parts, and one of their primary uses is as a "break-in" coating. The phosphate is granular, soft, and oil-retaining -- providing a useful degree of lubrication before oil gets to the parts. ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey June 2014
(No "dead threads" here! If this page isn't currently on the Hotline your Q, A, or Comment will restore it) Q, A, or Comment on THIS thread -or- Start a NEW Thread Disclaimer: It's not possible to fully diagnose a finishing problem or the hazards of an operation via these pages. All information presented is for general reference and does not represent a professional opinion nor the policy of an author's employer. The internet is largely anonymous & unvetted; some names may be fictitious and some recommendations might be harmful. If you are seeking a product or service related to metal finishing, please check these Directories:
Finishing About/Contact - Privacy Policy - ©1995-2025 finishing.com, Pine Beach, New Jersey, USA - about "affil links" |
