Mirror plating for rigid plastic sheeting
Q. Dear sirs,
I am working on some experimental solar projects and have been looking for high quality reflective materials. Aluminum foil is being used successfully for a solar oven, but I would prefer to use a light weight sheet material where a mirrored surface could be maintained. A friend suggested a chrome plated plastic sheet, but I have not been able to find such a material. The material would have to be rigid enough to remain flat through various temperatures, and light enough that a 12 foot in diameter parabolic dish could be safely manhandled.
Gordon J. Hoffman- Lewiston, Idaho, USA
Q. I wonder if there is a weatherproof thermoformable mirrorised ("sandwiched mirror coat") sheeting available?
Stuart Smyth- Wicklow, IRELAND
A. Hi Stuart. Although I don't know whether such a product is commercially available, I think you're on the right track. I think an aluminized coating would be much more reflective than chrome plating. I have seen inexpensive mylar balloons that are aluminized and, although neither the durability nor rigidity would be great, perhaps you could just fasten the aluminized mylar to a transparent polycarbonate disc.
September 2018
