Want Sprayable Ceramic Coating for my Exhaust System
I have a very expensive exhaust system on my car , and would therefore want to coat the connections especially , where rust first occurs . Do you manufacture a ceramic or other type of coating that can be easily applied from a spray can without removing exhaust system from car ?
David Isaac
- Beamsville , Ontario , Canada
Hi, David. It wouldn't really be a ceramic coating if you could spray it :-)
A real ceramic coating is a glass powder frit that is melted on at extraordinary temperature to coat the thing in something similar to melted glass. But there is high temperature paint [affil links] that may or may not have ceramic particles in them. And their salespeople will call them 'ceramic paint', although only the particles are ceramic, not the coating.
June 25, 2008
