Powdering of Cadmium Plating
I am seeing sublimation (powdering) of cadmium plating on aircraft hardware inside a wing which is only 4 months old.
The aircraft has been on the east coast since late April. No other corrosion is evident in the wing.
David G. Monsen
aircraft. - Afton, Wyoming, USA
It is important to determine if it is truly the cadmium plate that is powdering or is a conversion coating that was applied to the cadmium powdering? This would have a significant difference in what my opinion would be.
Gene Packman
Is some kind of chemical or moisture being sprayed onto the part or area where the powder is observed?
tom & pooky   toms signature
