How do I smooth the rough brass on Muzzleloader?
I have just bought a muzzleloading kit (gun). 20% of the hardware is brass, but in the unfinished state. The brass is not smooth, it is rough to the touch. How do I go about making the surface smooth?
Patrick Screan- Huntington Woods, Michigan
Hi, Patrick. This is simply a mechanical buffing process -- which is not meant to imply that it's either fast or easy :-)
As you finish up you will be using a very fine buffing compound on a very soft buffing wheel. But trying to get rough brass smooth with that would take longer than digging a foundation for a house with a teaspoon. So basically, and again I don't say it's easy, you start with a rather course polishing compound and, in a series of perhaps 6 or 8 steps, you get all the way to mirror smooth.
I would suggest that you practice on some expendable brass rather than on your new muzzleloader. Good luck.
