PROCESS DONE ON MILD STEEL
MY QUESTION:
1) WHAT IS THE PROCEDURE FOR POWDER COATING MILD STEEL?
2) GIVE ME THE DETAILS OF BLACKODIZING? THE PROCEDURE FOR BLACKODIZING ON MILD STEEL
3) HOW CHROME PLATING AND BLACKODIZING IS DONE ON MILD STEEL?
AVINASH LAKKUNDI
- HUBLI KARNATAKA, INDIA
Blackodising on ferrous metals. I would like to know the detail process of blackodising and chemicals used with composition
Shashikant More
Machine building - Mumbai
Our FAQ on black oxiding is a quick beginning, Shashikant. Beyond that you will need to get a book or two from our "must have" booklist. The reason Avinash's inquiry remains unanswered after being viewed by thousands of readers is most likely because people realize that it just isn't possible to condense a shelf of books into a couple of paragraphs :-)
I want to know about the anodizing, blackodizing & chromotizing processes & materials used in that processes in detail.
Shripad Kulkarni
Waste water analyst. - Pune, INdia
Hi Shripad. The best single volume to get you started on this is probably the Metal Finishing Guidebook. But Clarence Roy's "Operation and Maintenance of Surface Finishing Wastewater Treatment Systems" ⇦[this on eBay, Amazon, or AbeBooks affil links] might be especially helpful to a waste water analyst like yourself. Good luck.
