Bonding to Nickel Aluminium Bronze
Bonding to Nickel Aluminium Bronze: Is there a pretreatment process that will improve the bonding of paint primer or 2 component neoprene adhesive to Nickel Aluminium Bronze that will be subject to immersion in sea water for extended periods? We are considering using a chromate conversion chemical that is usually used on aluminium, is this likely to help?
Greg Schultz- Adelaide, SA, Australia
