Chrome Stripping
I have been told that an arc welder can be used in place of a rectifier for stripping chrome in a bath of sulfuric acid. I have a welder that runs at about 30 volts 200 amps Would this do the job? And what size bath and acid concentration should I use ?
Jeremy Wooster
metal polishing - Cairns, Queensland, Australia
Are you trying to strip off only the chrome, or do you want to strip off all plating of a copper-nickel-chrome plate?
tom & pooky   toms signature
