Temperature vs oxidation on metals
I would like to know if anyone has done a research on time and temperature vs oxidation on Phos-Bronze. Is any graph or chart is available that tells you storing the material at x temperature for x time is = to having the material at 25 deg. C for x days.
Elyas Solooki
- Lake Zurich, Illinois
Maybe you will get lucky, but I think the information you are requesting is too specific. I do not think anyone will have this information. Perhaps you should try setting up an experiment and publish this data in a technical forum?
tim neveau
Tim Neveau
Rochester Hills, Michigan
