Test method SAE J2334
Hi,
I need to know where I can get a copy of the test method
SAE J2334.
Washington State Dept. of Transportation - Olympia, Washington, USA
This standard can be purchased from SAE on their website at www.sae.org.
Cynthia L. Meade- Sylvania, Ohio, USA
Marine salt water corrosion tests. I manufacture loudspeakers for marine applications and need a corrosion test for steel and other metal parts. I was planning on using the ASTM B117 be see some info indicating this test does not seem to correlate well with real life statistics.
Does this new SAE J2334 fit this bill even for heavy salt water environments? Or is there some other test?
- Santa Barbara, California, USA
