Does salt corrode aluminum?
Will salt adversely affect an Aluminum casting? We manufacture sifters that use a cast Aluminum housing. The product contains 30% salt. Will this corrode the Aluminum?
Joe Skafar
- Cicero, Illinois, USA
You betcha!
Victor Waldman
- Naugatuck, Connecticut
Yes
Martin Trigg-Hogarth
surface treatment shop - Stroud, Glos, England
We know that aluminum is NOT resistant to seawater; pitting occurs. I do not know if dry salt will react with the aluminum over time...but air moisture would be a factor there.
Mary Ross
- Oklahoma City, Oklahoma
White corrosion will break out like a rash. An Inexpensive way to protect this would be to use masking compound used in electroplating to be applied all over your sieve.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
