Seeking Aluminum
I am looking for aluminum sheet as follows: Material: 5052H34 Aluminum, 0.060 - 0.066 thickness Hardness: half hard Ductility: (Physical property ranges) Tensile strength: 34000 - 41000 Minimum yield: 26000 Elongation: 6% Can anyone help?
- SF, California, USA
Hello EH!
Well, the numbers you've given for the mechanical properties are right out of the Aluminum Association's book on 5052-H34 aluminum sheet. So all you need to do is contact your local aluminum supplier and ask. Check the yellow pages, and take a drive. Places that have a minimum buy quantity may forgo that if they don't have to ship it.
Lee Gearhart
