Testing of Coatings
I would like to know exactly what does an MEK 50 double rub Test prove when used on Powder and Wet 2 Component Coatings?
Scott Jones- Winnipeg, Manitoba, Canada
Dear Scott,
MEK double rubs test the coating's resistance to solvents. The
"double" means passing the cloth soaked with
MEK / methyl ethyl ketone up and then down - that counts for one double rub. I think this test is OK if you want a decent gauge on the resistance, however each person will apply a different pressure on the surface, so by no way is this completely accurate. However, I think I've seen a machine that will do this that will have a uniform pressure, but that will cost some bucks.
G. J. Nikolas &Co.,Inc.
Bellwood, Illinois
