Electroless copper plating on plastic and its catalysts
HI,
I RESEARCH ABOUT ELECTROLESS COPPER PLATING ON PLASTICS THIS IS MY PROJECT I READ MANY TOPICS ABOUT IT BUT I CAN'T FIND A REPLACE... ...MATERIAL FOR "PALLADIUM CHLORIDE" THIS IS CATALYST & THIS MATERIAL IS VERY EXPENSIVE I WANT SOME KIND MATERIAL THAT ARE CHEAPER.
THANKS BEFORE YOUR HELP.
GOOD LUCK & BYE,
Behnam Shayesteh DarShiraz university - Shiraz, Fars, Iran
by Sha, Wu, & Keong
AbeBooks
Dear Sir,
The current COSHH replacement is Ethylenediamine, which is not a barred substance as formalin is. I have lost all my notes on electroless copper plating so I am suggesting the above from memory. I did, however, successfully implement a working process whilst at another company, which included; electroless copper plating, nickel, and gold. If you have any information to supply me, I would be very appreciative. I could give you some advice on the topic if you so wish?
Best wishes,
Chris Langham- UK
