Waste Treating nitric that was used for stripping and etching Aluminum Zincate
Need some advise on treating nitric acid from our aluminum plating. We need to take the zinc out before we neutralize it, or if there is any way to batch treat the zincate with the nitric acid to precipitate out the heavy metals.
Angie Molnar
Westaim Corporation - Fort Saskatchewan, Alberta
You can complex the zinc by inorganic agents and then remove the complex with ion exchange resins.
Juzer Jangbarwala
Hydromatix, Inc. - Santa Fe Springs, CA-USA
