Potassium Hydroxide and Sodium Hypochlorite
I am a product development chemist. Currently I am preparing a cleaning chemical solution which contains sodium hypochlorite and potassium hydroxide crystals as major components. The solution is clear, yellowish and stable at 1.75% NaOCl and 14% KOH. When the components are increased (2.1% NaOCl and 25% KOH), I initially get the clear, yellowish solution but after a day it turns to pink and forms suspended black particulates. Why does this happen? I was told that it could occur due to metal impurities but I made sure that I used all equipment made of glass, and still the solution was unstable.
Kae Marquez
- Philippines
This could be due to co-precipitation of hardness salts (calcium and magnesium) with iron. These components will exist at low levels (ppm) within the raw materials used.
Steve Holland
- United Kingdom
Try using a more concentrated form of the solution. I had the same problem, my original components were far to impure and proved thus very unstable.
Rachel Corbin
- Houston, Texas
November 20, 2009
