Rapid test
Hello,
There is a rapid test procedure for corrosion resistance of phosphatized parts. Can you tell me about it?
Best regards,
Gate Ara - Tehran, Iran
Salt spray testing is the standard accelerated test for corrosion resistance. Look at the ASTM B117 specification. There are other tests out there, but I am not aware of one that is specifically for phosphating.
Tim Neveau
Rochester Hills, Michigan
